Looking for a Trust rear spoiler
Looking for a rear window spoiler as well.
If anyone has a lead or could possible ship this stuff to the USA please contact me. Its impossible to find any parts here.
Welcome to SAU Derek.
Look at F/S thread here on SAU + Post up a thread in WtB section too for your parts > good luck
And how on earth can you get away with a non-approved Skyline GT-R in USA? In some states you can have them? Other states they're crushed?
Excellent!
Is that your car mate?
If so, what size tyre are you running? im guessing they would be 18 x 10.5 +15? I have a set of 275 40s at home already.
Unfortunately it is not mine. He is a member of JDMST and it is a very nice example. Correct, sizing is 18*10.5 +15 all round.
GT-R looks terrific Grant!
If only it were mine Terry :(
I'm still stuck with the POS GTS-t on the previous pages lol.
i dont know for sure, but i was under that when the cars get to a certain age, they're a-ok in some states.
Excellent!
http://www.skylinesaustralia.com/forums/topic/393546-my-97-series-iii-bcnr33/
That's his build thread on here and I think it may have more details in his blog that's in his sig.. :thumbsup:
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
