Without the grills, there is plastic mountings exposed under the lights which make it look like somethings missing, (but not as bad as gaping holes in the bumper).
The tabs could easily just be cut off though, no probs, and yes they will fit a 2 door.
I put some coupe fogs on for a while. Straight swap.
I cut the grille bits off mine leaving the top section that hides the bolts. The grilles look like anus tbh.
Dunno if I posted this one here, I hope not. It's hard to get new photos when it just sits there.
sedan ones look much better but still not a fan personally... making a sort of diffuser/bash plate to follow the shape of the bumper & under the k frame at the moment so not worrying bout the lights, will give me some time to think..
Nice and clean miguelone
i see what you've done there Miguelone. looks like the way to go about it.
Takz ive seen this pic before but could find it again..thanks for the repost so i can have a better look. :) they do look good with the Nismo lip.
That is mad Taks seeing yours and miguelone's may change my mind, no harm in having 2 options.
im loving all of the standard bumpers around here all you seem to see on the street is body kits.
those bumper lights always looked to me like they are upside down...if you were to flip them 180 degrees so the wedge was on the outside and on the bottom it would flow much better with the headlights..Nissan design fault i guess :P
Anus grill user reporting for duty.
I ummmed and aarrrred for ages but I think I'm happy I kept em.
Look a lot better on black, tend to look too fiddly on lighter colours imo. Are your guards completely stock or are they pumped slightly?
That's exactly why I changed my grill from the double slat Sedan style to the single Coupe style. The whole front looked a bit too busy.
Soooooooooo... Dark Anus For The Win !!! Wasn't he the guy in StarWars?
Those ^^^ lights do look kinda nice with the yellow. Is that just tinting put on? Certainly would help to hide the yellow fever.
I need to fix up some cracks in my lip and put it on, but for now, after a fresh wash and complete with anus grills, my baby looks like this...
nice man very clean, do you like the chrome window trim cos i reckon it would look great in matte black
i know it needs heaps moar low haha, the coilovers are wound down as far as they go, need to get some adjustable tube ones, it still is like 9cm off the ground at the front. but i agree with you it still needs more
i kinda like the unfinished, empty look of the front at the moment, but i change the look so often i will get over it in a week or so and do something new, gotta keep mixing it up.
Edited by PaulosECR33
I don't mind the shiny, goes with the rims and fits with the weather shields cause they have it too.
I'm thinking of maybe painting the wheels black instead of the goldy bronze but leave the shiny lip.
If I had all black wheels, maybe the chrome could go black too.
Edited by Not a Pulsar
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
