Tastes are individual, just like your’ve expressed.
I can give my opinion. This is a public forum. Otherwise don’t post ya car up if you don’t want it to be commented on.
I am sure whatever I say isn’t going to change anything, it’s not ment to & if you’ve seen (in your opinion) fuglier wheels & graphics on ‘lines I hope you informed ‘em of their wrong doings…Less rice more spice….
so how do u know it has no spice? or do u just judge a car by how it looks, wether its got plastic all over it or not?
stop the bagging man seriously whatta bunch of spoiled bratz!!!
i would love to have his car. yes i'm saying coz i have an n/a but seriously put some side skirts and lower it a bit and should look tops! as for the decals i honestly don't mind them at all, blue goes well with the silver. not a fan of the rims though but end of the day each to their own.
No i haven't.....................what does bagging someone's car acheive? If they ask; i state that they are not to my taste, but each to their own.
at least his car is getting attention...I posted mine and no one said anything....i'm gonna go emo :D
has to be done :(
taken from here :O much laughs
http://shadowdane.shackspace.com/cats.htm
Edited by Madaz
yeah it was a 2 tone paint job but im not a fan of that look,
this is it b4 respray, tint, suspension
Me too!
Much prefer what you have done.
The first Skyline i was about to buy was that colour, but the guy didn't want to budge one cent off his asking price, so i moved on.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
