My Slyline, Jay Stylez have u driven through bowral a couple of times before? swear its yours ive seen going back a fair few months now but
Was this car at JEM last week?
It was on the dyno i think. Was the engine built by Autosport? Heard you have had some bad luck with engines?
ah its no drama..one night of snow and light and flufffy...Was too smashed xmas too put it in the garage and we had 50cm overnight..Fairly common here..Only damage was my body..shocking hangover and hour to shovel the car out..
Edited by elrodeo666
A snow flake is light and fluffy, that on the other hand is not so light and fluffy.
ie: 1 tonne of feathers is still as heavy as 1 tonne of iron.
But i was mainly referring to the environmental conditions the car is in and all the inherent issues that it will cause over time.
Where do you think every other Skyline in Australia came from?
The enviroment here is super dry in winter, much much drier than say most places in oz, thats why so many aussies come here for the snow, its the driest on the planet. Car is normaly garaged ! Seeing I've been here for nearly 10 years my concern to you would be the fact A) I know the history of my car
(B) most cars here sit in car lots for god knows how long without being started before they ever make it to auctions and they cop the full brunt of weather and acid rain,
© most japanese drivers wouldnt have a clue where the dip stick is..they drive their cars, put petrol in , and most dont dervice their cars until they have to do rego (shakken) which is every 2 years..
Trust me, a bit of snow is nothing compared to what I've seen some GTR's go thru before being shipped off to auction..
I'd take 50cms of Hokkaido light fluffy super dry snow sitting on my car for 1 day anytime compared to harsh aussie climate.
What's your point???? :D
Not all imports come from the snow covered mountains. The cheaper ones are covered with rust due to the salt roads in these areas. Just raising the question whether someone would buy a cheaper import if they saw the car covered in snow, like that one was.
^^ thats mint.
rekn you should swap the wheels off your GTST tho, and lower it a tad :D
Cheers ;)
I actually sold the work wheels of the gts25t a couple of weeks ago, they wouldnt have looked very good on the gtr because of their sizes and offsets anyway, not to mention they had different sized tyres front and back so would mess with the ATTESA.
I agree with the lowering part, it does sit a little bit high, but overall i am actually very impressed with the stock suspension so might just go with some Tein springs and also some wheel spacers, should make it look a bit nicer!
Edited by nizmo_freek
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
