Hi
I'm putting this up for a mate he has a r33 rb25det. now at the moment hes running out fo fuel due to stock injectors, has power fc supporting mods blah blah blah.
Now I know that s15 injectors fit into the rb25, some people on here prob use them think there 440cc.
But one thing from memory is that people with s13/14/15 can use rx7 injectors as they fit the sr and provide an extra gain going to 550cc, so my question is.
Can the rx7 injectors (550cc) work on a rb25det, do they have the same impedence, or is there another cheapish upgrade out there
Any help muchly appreciated,
Thanks all
https://www.sau.com.au/forums/topic/130505-rx7-injectors-in-rb25-or-similar/
yeah ive read you can use rx7 injectors which are 550cc (ish)
but youll need to find 6 of them of course. its probably easier and cheaper to just buy a set of 6 injectors instead of 4 and then 2. also s15 manual jdm injectors are in the similiar boat, but are 480cc.
You need the series 6 "primary" injectors from memory
The secondary injectors are higher flow again
Since there is only 2 primary injectors in a 13B, you need to find 3 sets, which is not easy
I think the WRX boys want them too
I went thru this a while ago, and ended up getting S15 injectors
There has been much debate whether they are 440/448 or 480cc
On NS.com, the majority say they are the lower 440cc, not the 480cc
Do half a job and you will get half as good a result.
RX7 injectors are very unreliable. Especially the S4/5 ones. They only operate effectively to a duty cycle of 60%.
A set of sard 550cc injectors you can get for $750 delivered to your door. Why would you mess around with anything less?
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
