Hi
I'm putting this up for a mate he has a r33 rb25det. now at the moment hes running out fo fuel due to stock injectors, has power fc supporting mods blah blah blah.
Now I know that s15 injectors fit into the rb25, some people on here prob use them think there 440cc.
But one thing from memory is that people with s13/14/15 can use rx7 injectors as they fit the sr and provide an extra gain going to 550cc, so my question is.
Can the rx7 injectors (550cc) work on a rb25det, do they have the same impedence, or is there another cheapish upgrade out there
Any help muchly appreciated,
Thanks all
https://www.sau.com.au/forums/topic/130505-rx7-injectors-in-rb25-or-similar/
yeah ive read you can use rx7 injectors which are 550cc (ish)
but youll need to find 6 of them of course. its probably easier and cheaper to just buy a set of 6 injectors instead of 4 and then 2. also s15 manual jdm injectors are in the similiar boat, but are 480cc.
You need the series 6 "primary" injectors from memory
The secondary injectors are higher flow again
Since there is only 2 primary injectors in a 13B, you need to find 3 sets, which is not easy
I think the WRX boys want them too
I went thru this a while ago, and ended up getting S15 injectors
There has been much debate whether they are 440/448 or 480cc
On NS.com, the majority say they are the lower 440cc, not the 480cc
Do half a job and you will get half as good a result.
RX7 injectors are very unreliable. Especially the S4/5 ones. They only operate effectively to a duty cycle of 60%.
A set of sard 550cc injectors you can get for $750 delivered to your door. Why would you mess around with anything less?
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
