Hi guys, I had a problem with 4th gear at Sandown on the weekend... when shifting from 3rd to 4th, close to redline say above 6,000rpm, I was getting a nasty crunching sound... now it would still go into gear fine and it was only happening when I was trying to shift quickly (if I eased it in there was no sound, but it meant for a fairly slow change)
...so my question is, do I need to get the box out asap and fix it or can I get away with a few more trackdays/drags etc without losing 4th gear altogether? Am I stupid for not worrying about it? (Maybe I can smash the whole lot so I am forced to go out and by an OS giken gearset hehe)
https://www.sau.com.au/forums/topic/130510-syncro-on-4th-is-not-happy/
Hey,
When the gear is crunching you are doing damage to the sleeve that actually does the job of engaging the gear.
Yep, your 4th synchro is most probably worn.
Do this enough and even without breaking anything else you'll burr the front of the teeth on the sleeve - which
will probably make it difficult to get it into gear and then keep it there.
Getting replacement sleeves for some boxes is hard (e.g. I can't get one for my 32GTR box; I have to
upgrade the entire 1st-3rd train in order to be able to use a different 4th sleeve). Your box might be different.
Don't know your box; but on mine 1st, 4th and 5th synchros are 1-piece; 2nd and 3rd are 3-piece.
This is probably why 4th seems to go first on GTR boxes :)
The long and the short of it - I would fix the synchro before you do more damage. They are wearing parts
and should be relatively cheap to replace - the hardened sleeves and/or gears are _not_ cheap
to replace assuming they are even available. You probably want to do 3rd and 4th synchros.
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box :)
Regards,
Saliya
Redline themselves say that the shockproof is not to be used in synchro boxes.
I know that everyone on here thinks it's the bees knees. they put it in their box and it shifts like new. I totally agree there.
My issue lies with box longevity. Basically, a thinner oil allows you to shift smoother. e.g. if you put atf in the box. But also, it's a catch 22, it'll shift smoother for a dieing box, but it'll wear out much quicker too.
Lets just say that my box is notchy too. I just live with it. I'd prefer to kill it by notching it occassionally, rather than it dieing from redline shockproof.
Hey,
This is probably why 4th seems to go first on GTR boxes :mad:
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box :stupid:
Regards,
Saliya
I am pretty sure the 32GTR and 33GTSt boxes are very similar and I am now seriously considering a freshen up before I do damage to more than just the synchro, thanks for your help
Hey,
This is probably why 4th seems to go first on GTR boxes :D
Do a bearing set while you're in there and you'll probably get another 10-15 years of motoring out of the box ;)
Regards,
Saliya
The syncro may be cheap but getting it installed isnt thats for sure I had mine done 3 years ago costs a bloody fortune.
cheers
cheers
Put it this way: the labour cost is going to be roughly the same whether you do 4th gear synchro only, or an entire
rebuild on the internals of the box (getting to the 4th gear synchro probably requires complete disassembly).
So it might be 'a fortune' now; but when a sleeve is burred or smashed and it's not replaceable, it's 'a fortune' plus
another few large :)
(Yes, you can buy secondhand drop-in boxes of similar vintage - but aside from the 'you haven't seen it running
and/or disassembled, so how do you know it's any good' factor, any box that's of roughly the same mileage will
probably have roughly the same problems...
Regards,
Saliya
Got the exact same problem with my 'line last nite.
Shifted up from 3rd to 4th at about 5000rpm, nasty crunch.
Looks like the box will be comin out to replace teh synchro's. fun! :huh:
dont feel to bad mate.. i was shifting from second to third in my 34 gtt and ripped every single tooth off third. the box was like new up to this point and showed no signs of wear (even had perfect syncro on reverse which is almost unheard of)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
