The syncro may be cheap but getting it installed isnt thats for sure I had mine done 3 years ago costs a bloody fortune.
cheers
how much roughly is a fortune? my 33 crunches from 1st -2nd. Man not looking forward to this
Your looking at $1000+ for gearbox rebuild..
Approx. $350 + gst to pull down and replace the box..
Approx. $400 + gst to replace any parts, check everything, rebuild..
+ Parts..
hmm thank god i thought it was gonna be $2000+ still expensive tho, any place you guys can recommend for this sort of work?
How'd you end up going - find somewhere to get it done??
Reason why people recommend getting the gearbox reconditioned because of the fact that atleast you'll know what life it's lived..
And also - cubes wants a cheap second hand box ;)
I bought Redline shockproof for my GTR and just did the change, what a difference.
I also had crunch from 3rd to 4th.NO CRUNCHING NOW. ;)
Reading the specs, the Burson's sales staff after asking my car type said the redline-shockproof was the oil required for the gear box .
So why are people saying not to use it? It is on paper from redline as a dirrect replacement oil.
Try Redline first, then see if it works. Cost $110 4L approx.
Do a gear box re-build when it's nakkered
havent't look for a place yet, the crunch is not really bad and doesnt happen all the time, im just preparing for worst case scenario.
dont worry you are not the only one, my 1-2 and 5th crunchs, but my problem is wat oil do i change to, currently its running some castrol oil, do i change over to a thick or thin, i know 2 mechanics and both are saying differently, logic says thick to stop the metal grinding, i notice redline shockproof gets mentioned alot here
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
