I've fitted a set of R33 GTR brembo's to a R33 GTS-T before and was a straight boltup pretty much and I imagine the mounting brackets are exactly the same to the R32 GTR. All that was needed for the conversion was larger rotors and the original brakes lines from the 33 GTR. If the lines weren't included they can be done up easily at most brake joints. Plus you might as well upgrade to braided lines if your going to the trouble of doing so. Braided lines made in Australia are legal as well, as far as I know.
they fit, (discs and calipers) you need to modify the brembos slightly to fit the stock 16inch wheels. a
15mm bolt on spacer is needed.
good front track increase too :huh:
about 3mm needs to be linished off the calipers outer diameter (the part closest to the rim) as its not flat. this is so the wheel can spin... etc etc
apart fom that its very straight forward :)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
