After "Nurse Debbie's" little chat last night, you now all know why we need to give blood.
My next appointment (it will be my 94th!) is scheduled for after 30 August. While I ordinarily donate mid-week at the Bourke St centre, I'm willing to make a change to a Sunday at Southbank. To do this, I need your support.
If you are genuinely intertested in becoming a blood donor, please email me with your intention. I need to know by Friday next week (August 25) so I can try and organise a group booking on the 3rd or 10th September.
https://www.sau.com.au/forums/topic/130529-give-blood/
Reminder that some of us are giving blood Sunday (September 24) at the Red Cross's Southbank centre (Cnr Balston and Kavanagh Sts, South Melbourne). If you aren't giving, why not cvome along to lend moral support.
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2510599
You need to have eaten something before you donate. I suppose we could do "morning tea" afterwards, although Red Cross supplies all those yummy nibblies after your donation.
And you need to have had a reasonable intake of fluids beforehand as well (NON-alcoholic, Brisby!!!!).
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2513421
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
