Ok a mate has a Garett GT25/40 Ballbearing going for $1200
History - Purchased for $2400 (2 years ago) was put on a rice boy silvia with a highmount manifold, the dude ran it for 2,000 km of show car engine life running 10 PSI (dumb), the turbo is a perfect upgrade for high horsepower applications, too laggy for his silvia, removed it to use a small one and sold it to my mate for $1700 about a year and a half ago... mate was going to use it on an rb30et but the exaust shops said it has a rear housing too small for a big boost 30, He has wanted to sell it for a year but never got around to it...
It is a perfect upgrade for big power on a 2 litre motor, also really good on a 2.5 litre motor, still provide lots of hp on an RB25 or a 1JZ
This turbo is in perfect condition availible to see thru arrangement in brisbane - It has no shaft play good bearings, no cracks or any defect what so ever... If your looking at upgrading a motor with the appropirate capacity this is the best turbo you could get your hands on... Don't forget garett turbos feature the most superior build quality/reliabity of all turbos... Much better then HKS, Turbonetics etc, they mostly modify garett turbo's anyway...
Specs
Inlet:
4" OD Front inlet
2" ID/2.3" OD Outlet
AR70 Housing
Exaust:
T25 Flange (SR20 flange)
.86 Rear (good for a 2 2.5 Litre motor)
Rated at 450HP
Internal Wastegate
It has a speedflow fitting worth $45 on it ready to be fitted up to a motor
Pics
Add on horsepowerinabox.com:
Garrett GT25BB 450hp ball bearing turbo
This unit has a T25 type base flange and GT25 type rear flange for the exhaust. Features a huge .70 comp cover with smooth machined bellmouth inlet and 4" inlet. This unit has a .86 exhaust housing in this 450hp form . The comp wheel actually flows 44 LBs/Min and itself is rated near 450hp. Usual ultra reliability and superb response from the Garrett ball bearing design. Sometimes called a GT25/40. Very similar to the HKS GT25/40 but with a different comp cover and different number of blades on the compressor. Great upgrade for SR20DETs and other 2 litre's. A little laggier than the 400hp unit due to the larger exhaust housing.
Price:
$2,099.90
inc GST within Australia
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
