Hey this may sound like a dumb question and NO I haven't tried it yet but....
Installed a HKS evc the other week and need to calibrate it.
Don't have anywhere I can boot the car to do this, and don't wanna do it on the street ....so was wonderring if it is safe for me to jack the car up, put it on stands and drive it. (Like an excersise bike:) )
Or do I risk the car jumping off the stands or something worse?
It actually sounds quite stupid to me but was wonderring if its possible?
Thanks!
https://www.sau.com.au/forums/topic/130556-is-this-safe/
its not safe and even if you did it, its not accurate. the road will give different load rating and affect how the solenoid will turn on and off. just do the self learn in a quiet street or private road somewhere.
youll need about 100meters odd to do it, so it should be fairly easy. sit in 3rd gear. take off in 3rd (youll have to ride the clutch) then full throttle till it beeps and changes to -2-
then do a u-turn, repeat until you get to -1- and then finally it will change to normal operation mode
https://www.sau.com.au/forums/topic/130556-is-this-safe/#findComment-2415963
Thanks!
No it won't work you need the load.
Dyno would be the safest way
https://www.sau.com.au/forums/topic/130556-is-this-safe/#findComment-2415975
yeah just put the nose up against the garage wall and go hard with the gas pedal. let the car change gears as it needs to. you should prolly have your sister stand to the side of the car with a big palm leaf to blow cool air into the radiator... better to be safe than sorry right?
https://www.sau.com.au/forums/topic/130556-is-this-safe/#findComment-2421128
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
