Hi guys.
I have a 95 type M R33 and i have a sunroof.
A question, when it rains what happens to the water if it gets into the sun roof channel. It seams like the back of my sunroof does not quite sit flush with the roof of the car, and if you press down on the sunroof a gap forms in the seal and the roof.
Is there any way of adjusting the roof to sit higher or something.
Has anyone got a pdf or something showing how this can be done. Some pics would be nice.
https://www.sau.com.au/forums/topic/130589-r33-sunroof-question/
You can place extra spacers where the sunroof bolts up to the rails.
All you need to do is take the two plastic covers off, which are accessable from the underside of the sunroof and you'll see where the spacers are... just place more until it forms a better seal... I did the same.
If however, your sunroof seal looks worn and is cracking, i'd advise you to replace it as if you get water between that and the sunroof glass bit, the frame around the glass will rust (i had to replace mine).
As for where does the water go, there are drainage holes at each far corner of the sunroof frame, they allow the water to run out through hoses.
hope this helps
cheers
Liz.
HI can you bit a bit more specific in regards to the plastic cover part, not sure what you mean. I only have had the car for 3 days.
The seal looks great, no probs there, i just figured there would be an easy fix on the rail itself.
Do you have any scaned photos of the manual or anythign like that. I have a pdf on cd but i left it behind.
How do you actually remove the sunroof glasso out of the tracks, i need to clean the rails properly, the old greas sux.
Thanks
Yeah no worries.
Ok.. if you jump in the drivers seat and look from that angle you'll see a plastic screw on each side of the sunroof, undo them both and you'll find that the plastic cover will be able to be popped off.
Once you see how to do that, there is just three bolts on each side that you'll need to undo, after that, the glass bit of the sunroof just lifts out.
Sorry, I don't have any photos and i don't have the car anymore tog et any. But you should be able to see how to do it, just look for the plastic screws and you'll see the rest easily.
cheers
Dam it, ok so i get in the seat, and look towards the front or the side or back.
are the two plastic screws easily visable, i can't find anythign there.
Are you meaning the cover that has the swithes on it?
dam it sorry mate, like i said i have only had the car for 3 days.
look directly up at the glass... and then look to the left and right of the glass and towarsd teh back of it, you'll soon see the covers and the plastic screw, one on each side.
if you still can't find it and you are near your car, pm me your number and head out there and I'll call and talk you through it.
don't worry, took me ages to work it out myself lol.
hay, ok so i had a look, and the only screws i see, are located on the sunroof plastic, on the actual glass part.
Does your sunroof go in and out and up and down, cos i am sure there must be a adjustment somwhere to do it, what i do for now, is once closed, simply bump the up swithc a bit and it's fine.
those are the screws that you need to undo to get to where you can place the spacers.... the glass will just lift out once you undo those screws, and the bolts that are hidden by them... you'll see the spacers I'm talking about once in there.. just need to find another spacer (or make do)
There is no adjustment to do other than what i have mentioned.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
