Just wondering what would cause the Hicas light to come on while driving.
The other day I was driving (in the rain), when the orange Hicas light on the dash came on. The steering went really wierd, varying between too heavy and too light. After about 1 minute or so, I pulled over, turned the car off, turned it back on and the Hicas light stayed off, haven't seen it since....
Any idea what might have happened there?
check your power steering fluid in the engine bay and also the hicas 'bottle' in the boot (?)
maybe they are just below the 'line'
also check the connections to the battery for corrosion - I had an issue like that where one of the wires on the positive terminals was corroded and made an intermediate connection causing the hicas light to go on and off while driving.
Thanks guys, Merlin I must have missed your thread on my first search, but I saw it afterwards and answered some of my questions.
Seems a bit wierd that it came on once, then when I turned the car off, and back on again it never came back.
I think i will probably end up getting a lock-bar anyway, but I was curious to know why it may occur. I will check the fluid levels to start with.
my hicas light comes on afta awhile of being on a freeway, ive never worried 2much about it, my car has a momo wheel fitted, any ideas bout these tomai hicas kits?
Is the BOSS kit designed for HICAS?
I have used a Tomei Lock kit for the last 2.5yrs, works well and have had no problem. But if your Boss kit is NOT HICAS compatible, the HICAS light may still come on, so you may be required to remove the globe.
HICAS is the 4WS system.
Quinny: do you have an aftermarket steering wheel?
No, it is stock. The fact that I have not seen the light again could just be a glitch or something, but it is rather strange. I think I will probably get rid of it anyway, I have never been a big fan of 4WS.
hicas bottle in the boot?
wtf?
yeah there is a bottle on the drivers side of the boot, behind the boot lining.
i know my car is supposed to be 4WS but how much does the rear wheels move?
i have sat in my car with the door open watching the rear wheels as i turn the wheel completely and they never moved.... how would you find out if something like a "lock kit" is installed?
Best notify everyone that you have a 32 :). R33s do not have a resivour in the boot.
I believe the 4ws only operates when car is in motion
Isn't the remote resovoir the attesa resovior? Which feeds into a pump under the boot?
Whereas R32 hicas is taken from the power steering pump...
I dunno why it goes on. I fixed it by removing the warning light from behind the dash. No warning light, No problem...
And I doubt your car would have a lock bar.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
