Iv been thinking about getting a MSD 6A ignition controller for my MR30 for a while now but with the way petrol prices are at the moment im thinking about it a bit more seriously if it's gonna save me fuel so what i want to know is would it be compatable with the L24E and are they hard to install. Performance whise what difference would one make paired with a performance coil and a set of 8.8mm leads.
(If anyone has a secondhand one for sale i might be interested)
Ok next the cam, has any one got a aftermarket cam in there L24 or L20 what brand is it and what differnce did it make, Iv'e been looking at mild Crow cams and i will also be getting extractors to compliment the cam.
any help would be greatly aprisiated Cheers Josh
https://www.sau.com.au/forums/topic/130618-up-grading-my-cam-and-ignition/
If you want THE L seies n/a cam, go source a 260Z manual cam. It's reputedly the Nismo Works cam and it should have a C stamped on the back.
I'm using a stock L28ET cam in my new L20ET engine and I got it for AU$90.00 ex USA delivered to my door.
Cheers, D
So all the manual L26 260Z are supposed to have nismo works cams, it would be cheaper if i could get one of them but the only problem is it probably wouldn't be the grind i want the crow cam ive picked out is a high tourque cam that works between 2000rpm & 5800rpm.
what sort of power increase do you think you would get from using one of those nismo or L28ET cams, crow recon about 10hp from there cam.
******* CROW CAMS SELECT PROGRAM *******
16 COLBERT RD CAMPBELLFIELD 3061
phone (03) 9357 0469 fax (03) 9357 0001
MODEL TYPE
|-------------------------[CROW COMPUTER CARD]-------------------------|
| PART NUMBER 58643ohc Date 4-MAY-01 |
| Cam type: Asysmetrical profile Read in Head |
| Advance Ground on Cam: 1 Lobe separation: 108 |
| .075 VALVE TIMING ( Measured at the valve with no lash ) |
| Inlet opens: 0 BTDC Closes: 34 ABDC .075 Duration: 214 |
| Exhaust Opens: 37 BBDC Closes: -1 ATDC .075 Duration: 216 |
| ADVERTISED VALVE TIMING |
| Inlet opens: 41 BTDC Closes: 75 ABDC ADV Duration: 295 |
| Exhaust Opens: 78 BBDC Closes: 40 ATDC ADV Duration: 298 |
| Inlet lobe lift at TDC on the over lap:.075 |
| Valve lift Inlet: .4850 Inlet Rocker Ratio: 1.00 |
| Valve lift Exhaust: .4950 Exhaust Rocker Ratio: 1.00 |
| Valve Lash Inlet:.008 Valve Lash Exhaust: .010 |
| RECOMENDED VALVE TRAIN COMPONENTS Kit Number: |
| Valve Springs: Spring height: Collets: |
| Retainers: Pushrod: Lifters: |
| H/D Timing Set:
Edited by the big JC
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
