Hi guys
i've just purchased a turbotech manual boost controller and need a bit of advice about where it goes. I understand that it is to be installed in the tube between the turbo and waste gate actuator. I have identified where i think it should go on the pic below, could someone please confirm this, or instruct otherwise?
Cheers
Jeremy
https://www.sau.com.au/forums/topic/130621-where-does-boost-controller-go/
Hi guys
Cheers
Jeremy
Here you go. Bassicaly, remove the T-piece and install the controller the, the inlet side is the one opposite the bolt, the side is the outlet. BE carfull with these, make sure they are unscrewed just about out when you firt start to test, mine after one turn was at 10psi.
Disconnect the cable link form the original controller and either plug up the vacume hose or leave connected, makes no differance. Hope that helps.
BTW these controllers rock.
Thanks for your prompt replies. Could I be a pain and ask that you put a photo of your's installed. I'm a bit confused about which way it should point and why it couldn't just be placed between the two tubes I identified, because isn't that controller now redundant? Sorry that i don't understand this shit better...
humm digy not working.
The controller does go in between two tubes, but the main two tubes, you remove the T pice that is there currently. So basically that is the wastgate actuator not the selenoid, then disconect the standard selenoid.
there is a section in the forum about these i tried to search but no good, i'll try tomorrow for you
does any one know where the top hose on the selenoid goes to and how does it control the boost the actuator is set at 7psi how does it go down to 5.
Edited by RB SANDY
The hose connected to the top of the standard selenoid, goes to the vacume side of the intake, before the turbo, it is there to help the selenoid work , that it, nothing else, once the selenoid is not being used, it can be disconnected.
The standard selenoid, simply opens at 5 psi, a signal form the computer earths out the valve and sets the it to 7psi, or there abouts, they are not supper acurate.
TRUST me it will work, i have done this to two cars now, and they are all fine. I will take a picture over the weekend and post it up.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
