Hi,
I have a R32 GTS-T. Mods include full exhaust system, boost controller, coil packs, air intake and soon to be fmic and apexi fc. Just a question? Is it possible to get this baby to smoke your average R33 or R34 and even stand in the shadow of a GTR?
I've been told they have no bottom end but there must be a way to fix this? Any points of view out there. I just think that If I spend another $10000 or so on carbon bonnet, coil overs, bearing turbo, fmic and other items without knowing what its worth.
https://www.sau.com.au/forums/topic/130637-rb20-better-than-rb25-or-26/
  • Replies 49
mod for mod, the 25/26 wil always beat the 20 due to its extra capacity. however there are a few highpowered RB20's arounjd the place that with a grippy set up car would more then likely blow away a stock GTR...
as for having no bottom end.. well they are only a 2 litre motor, so you either need to rev them to get power, or add capacity
either way, i love my rb20, makes great power for bugger all bucks!
dollar for dollar spent... RB20 wont ever match an RB25/RB26
Its just not going to happen. Capacity dictates much more broad power curves so more power, for longer.
The only way to be better, is to spend more, and i mean a LOT more money than the other person
Hi,
How do you mean "beat" a GTR? Can the GTR be modified aswel?
Power FC, GTR injectors and a HKS GT2530 will give you 270ish rwhp, and a well powered, reliable and responsive RB20DET. going any bigger turbo will give you excessive lag, unless u like lag :)
Edited by _8OO5TED_
rb25 has a far better head for flow than rb20 so you're already losing
the 500cc difference means squat all in comparison in my opinion
rb25 isn't built any tougher than an rb20 though, so you'll bend or break things anyway
Dont forget, R32 GTSt is between 1250-1300kg. An R32 GTR more like 1550kg. So you dont really miss the torque as the car is reasonably light.
If you want general all rounf performance keep an eye on power to weight. An R32 GTSt with 230rwkws will not be a slow car. With sensible suspension, wheels and tyres it will do mid 12s at the drags, and be on par if not quicker then std turbo GTRs. (Gross generalisation but i think there is some truth to it)
The head flow thing is interesting as well. Sure the RB25 has bigger valves, but what is the ratio of the cc of each cylinder to the total inlet and exhaust valve face area?
I have never done the calc, but could be interesting. Ditto the SR20 vs the RB20, as each cylinder has less cc, and the smaller physical valve size may not be such a big deal when you look at it as a percentage of cylinder displacement.
rb20 = lag
but its f**king reliable and very kind to its owner...
not sure one could say the same for an rb26.. it generally needs money adn TLC to keep going from what i have read
With RB26 and being reliable, they need one good rebuild IMO and that cant include shortcuts, then go and abuse it however you please!
If you had a standard RB26 and didnt do boost exhaust etc and treated it well it would last for ages, the thing is, who buys a GTR to baby it? They're all driven as hard as they can be at one point in their life at least, and after 200,000k's in some cases you cant really blame them for bearing failure etc :O
Standard turbo GTR R32 running 15psi and clutch etc should do a mid to low 12 :laugh:
When are you GTR guys going to come to terms with the fact that your cars plain suck! :O
...lol and when are ppl going to stop comparing them? A neat GTSt will be a good all round car. A std GTR is a good all round car. From what i have seen a GTR doesnt have to be very modded to be an even better car, as the factory gave the thing pretty good gear from the start.
...doesnt change the fact that GTR owners have to use velcro shoes because they struggle with shoe laces :laugh:
Lol
I give credit where credit is due
I drove an R32 GTST, the boost never came, even though it was lighter than a GTR which was good i would still take a more peaky turbo/motor combo over the RB20 standard setup
:laugh:
Anyway this thread isnt about GTR vs the world, in answer to the question, you can get heaps of power out of the RB20 for the R32 shell (good power to weight i mean) but as for it matching a GTR, doubtful IMO, there are some out there with huge power, but power is no good without traction
...i dont :)
Im going to so kick some GTR ass at Wakefield....and if i dont ive got a long list of excuses already prepared. :)
LOL!!!
Ill be there, look for the guy hungover with an SAU shirt on and a can in hand - come say Hi :)
if u want reliability then stick with the rb20
funny that the rb20 is older yet seems there is many more 25's and 26's blowing up... maybe due to the fact that every man and his dog has either an r33 or 89 gtr
Also, the more powerful motors are thrashed harder IMO so they have a much harder life
Rebuild time is just a good chance to upgrade anyway :)
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
