rb20's are fullly sick
except for the externally gated ones. they're gay.
anyways
r32 - 2530 - 12psi - bilstein suspension - power fc (me)
r33 - stock turb - 10-11psi - stock suspension - stock ecu (liz)
@ oran park
r32 just keeping infront of the r33
alittle more work i think is needed for the r32's to keep up
  • Replies 49
GAY? I cant bite in fear of posting some offensive red neck comment that i dont really mean ...but there is something wrong in the heads of ppl running external gates :)
...and we all know this thing would slaughter both a lion and unicorn
GAY? I cant bite in fear of posting some offensive red neck comment that i dont really mean ...but there is something wrong in the heads of ppl running external gates :P
just having a stab in fear of the rb20's with external gates destroying my pissy turbs :(
but it is true when those external gates open..... brilliant i say!
When are you GTR guys going to come to terms with the fact that your cars plain suck! :D
...lol and when are ppl going to stop comparing them? A neat GTSt will be a good all round car. A std GTR is a good all round car. From what i have seen a GTR doesnt have to be very modded to be an even better car, as the factory gave the thing pretty good gear from the start.
...doesnt change the fact that GTR owners have to use velcro shoes because they struggle with shoe laces :O
:laughing-smiley-014:
RB3026 > all :)
Err, then how is it that a r32 gts-t with a 33/34 turbo on it, is faster than a gtst 33 or 34 with the same turbo and more technology? Assuming that 33/34 gts-t's run something like mid 14's in the quarter and your average 32 with a 33/34 turbo on it and minor mods will hit low 14's, maybe high 13's
Also, 32 gtr's hit, 13.3, 13.2 ay?
(the last page of this topic belongs in the wasteland -_-)
Edited by r32 gts-turbo
anyways
@ oran park
Georgey boy,
you can't compare the two, those times come down to driver experience and ability, if you want to go that way, i fried your ass in a total stock standard r33 gtst, and again at wakie.
Oran_Park_GP_29_April_06.txtwakefield_pk_2nd_july_06.txt
nathy boy
obviously your driving ability out does mine....... quite obvious!
so i was using liz as an example because i would say her ability and mine are similar. Dont you think??
As your pointing out she should of whipped my ass if she was at your level? right?
and i was refering to the aaron mcgill day not long ago not the renew day @ oran park.
my previous comments were based on the fact that two similar drivers in an r32 and a r33, the r32 would need more to keep up in my opinion. i think you took my post the wrong way mate. just have another read of it
werent u running semi slicks???
cheers
George
nathy boy
cheers
George
Sorry George, the thread is about rb20vrb25vrb26, useless if you ask me but people can't help themselves, mate the renew trackday was my very first time on a track!!! in any car and wakie only my second. No i wasn't running semi's at oran park but at wakie yes. to tell the truth i think your car should be faster as being lighter of the two and with mods. Stock for stock no i don't believe the rb20 is better or the rb25 better then an rb26, but if you mod the rb20 the right way it will be quicker than an stock rb25, you could also apply it to an rb25 over rb26.
but i my opinion dollar for dollar with same mods and tuning no rb20 will beat an rb25 and same with rb25 to rb26.
Screw the unicorn or whatever other animal you can think of.
If an rb20 wants to beat any other engine possibly known to man it needs help, and the help it gets is from the hippo, dance dance dance boys and girls and the hippo PWNS you.
I was actually pretty impressed with my little mildly modified Rb20det.
It only made 164rwkw running 1bar of boost with an exhaust & fmic.
Up and rolling it was as quick if not a bee's dick quicker than a 100% stock R33 GTR. Now thats not bad really..
It also never ever had issues and never had an R33 with the exact same mods beat it. My little R32 was always a little quicker.
A mate at the time had an R33 with the same mods but obviously making more power than I. His car clearly weighs more and has longer gearing. Driving the R33 vs driving my little R32 the R32 won hands down, it was so much more fun to drive especially when boost snaped on hard exiting a corner in second. He even stated the R32 felt quicker, and it was. :mad:
All though for some reason these days there appears to be quite a few r33's pushing 200rwkw on their stock ecu, back then it didn't happen. Most likely different dyno software or something.
Once you pass those first few mods the R32 gets left behind. They require a turbo upgrade that increases lag and makes the car just that little bit harder to drive.
I've never been in Roy's but from the dyno graph it does look impressive, looks like it has that 'fun' factor. :stupid:
An example is the crude power to weight.. Lets go with 1550 for the gtr and 1320 for the 32 gtst. The gtr needs ~30rwkw more in order to achieve a similiar power to weight. An R33... Needs roughly 15rwkw more than the 32 to achieve a similiar power to weight. Thats going off the 33 weighing in at 1415kg's. A friend had his on a weigh bridge some years ago. Power to weight comparisons are crude as, I don't like using them but it does help bring the weight issue in to perspective.
In conclusion the Rb20 will never make power easier than an rb25 or rb26 for that matter. The advantage it has is Nissan tied it up in a lighter car with shorter gearing that all works in its favour.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
