hi guys,
i've been trying to fix my attesa. i get 13 flashes on the led, so that means fore and aft g sensor or circuit. i can get the number of led flashes to change if i unplug the g sensors (variously from 11, 12 and 16) so i don't think the control unit is lying.
in multimeter testing i got the following results:
control unit harness side resistance = 34.5k ohms (i.e. between 30 and 50 k ohms)
control unit connector voltage = 1.97v (i.e. g-sensor faulty)
g-sensor side resistance = 27.2k ohms (i.e. g-sensor faulty) (not between 30 and 50 k ohms)
g-sensor vehicle-side voltage = 7.99v (i.e. g-sensor faulty)
i thought i'd narrowed it down to the g sensor. i removed the g-sensor and tried it again, this time out of the car. the resistance went up to 30k ohms (i.e. harness faulty).
my question is:
could removing the g-sensor like this somehow explain the (small) resistance increase?
as you can see, all my other evidence says it's a faulty g-sensor but i'd like to be sure. i don't want to get another g-sensor and then find out it's the harness.
any ideas?
sig.
Edited by sigsputnik
https://www.sau.com.au/forums/topic/130649-odd-g-sensor-attesa-test-results/
Hi Sig, nice work. I'm not sure how to diagnose dodgy harness but the g-sensors will have a little red line through that window on the top, when they are broken. Does this make sense?
Will your workshop allow you to try before you buy? ie. plug in a replacement and recheck voltages?
Sorry mate, I'm not much help today.
cheers mate - actually i forgot to mention, the shock window is not red at all. i guess i thought that perhaps the unit was dead, but not through shock, or that the mechanism for turning the window red was also stuffed.
i'm wondering if Consult would give me more information (i.e. whether it's worth buying a Consult unit to test this out).
no mate, not in sydney - don't worry about it, cowie, it's ok. i'll get a new g-sensor and then post back the results. it'll be an interesting adventure anyway.
i'll probably buy a consult unit sometime soon, regardless. seems like a useful tool.
cheers mate :mad:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
