i got my clutch changed about 2 months ago, and while driving home tonight, the clutch pressure plate cracked when i put the clutch in.
i limped home just and was able to get half way into the garage when it gave way totally. i had to push the car into the garage.
the place i got the clutch changed at (who i wont mention atm) has since closed down.
one of my friends thinks i should sue the guy is he doesnt agree to do somthing about it.
should i? do i have a case? .. i really have no idea.. really need some help here. im totally screwed :)
https://www.sau.com.au/forums/topic/130689-should-i-sue/
What you have said doesn't really make sense.
are you planning on suing the clutch company?
or the workshop?
was the clutch faulty? if so, have you tried to talk to the company?
People these days watch too many tv shoes. It's like sue sue sue.
What action will you bring against them?
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418702
Get a indenpendant mechanic to confirm whether the clutch was faulty (or it was improperly installed). If it turns out faulty, then write a letter to the clutch maker with receipts etc, saying that their product was faulty and you would like a replacement or refund.
If it was faulty installation, then there may not be anything you can do about it (particularly as the workshop has closed). You could try dragging it through the courts, but it is probably more hassle than it is worth because you would only get the original paid price back.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418746
Get a fancy lawyer and jam him up this guys arse.....If you can find him.
There must be a reason he is out of business and I bet you aint the only one chasing him. Def get another mechanic to look, someone you can trust, ask around on here who people use in your area.
what sort of clutch did you have fitted?
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418758
sorry i should have worded that better..
the clutch has worked, for the last 2 months.
ill give the guy who supplyed and fitted it a call to see what he says, if he is not willing to do anything about it, ill give the department of fair trading a call to see where i stand
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418775
had a heavy duty full face organic clutch.. dont know the brand at all.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418784
How do you know it was the pressure plate?
Have you dropped the box and had a look?
Follow Thunderbolt's suggestion, ask for a written report from the mechanic then deal with the situation in a diplomatic manner.
If you go ahead with "guns blazing", they'll blow your ass with a missle. Not all companies try to rip customers off, try to reason with them first.
Who knows, you may be at fault and over heated the clutch, etc. You wont be able to tell till it has been inspected.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418792
Well said
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418811
ok, lets jsut say that firstly, lawsuis are expensive. not worth the small cost of your clutch. Keep in mind that these companies ahve money. If you think it'll just end in small claims, that is unlikely.
Also, have you thoguht abotu just talking to them? Most companies value your business, and might just give you a new one?
Also, how would suing your mechanic help? he didn't break it did he?
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418812
i was saying that suing was sujested.
ill give the guy a call tomorrow to see what he says.. and if im not happy with the responce and he isnt going to do anything about it, ill contact the department of fair trading to see where i stand.
ive felt a pressure plate break b4.. this stinks of the same thing. the car had been parked in the shops car park for a while, and it broke when i was still in the car park. i was not pushing the car at all.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418856
:( I personally have near seen a pressure plate break.
Let alone it happening to the same person twice :P.
What were you doing for the 2 months b4 that?
I don't know you, so i am not having a go, but i have seen to many people break their diffs while "reversing out their driveways", just forget/ignore the months of mercyless thrashing and burnouts b4 hand :sick:.
You will need to inspect the cause/damage b4 passing blame.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418871
oh the last car wasnt mine, lol.. and ive seen it b4..
also another guy on the forum here has had his pressure plate collapse b4. i helped him change the clutch and when we took it out, all the rivits had pushed through the back of it.
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418887
i havent taken it to the drags or done any masave burnouts (tyres cost too much) . but its not like a had been thrashing it at all.. thats why im so shitty about it, ive never put it through anything that would result in the clutch failing like this
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418962
I've had a couple of pressure plates go in the past when I was young and much bodgier than I am now. :(
Never on the skyline though.
The problem I had came down to either 1. reusing a pressure plate or 2. a certian model car appeared to have a weakness in their factory items when shifted hard.
I started using new pressure plates and threw heavy duty item in there.
A pressure plate that has failed will look flat and typically have its fingers at different heights, from the ones that I did anyway.
HOWEVER, it has been known for the skyline box's to squash the pivot ball. So that may be worth looking at before jumping the gun. :P
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2418991
might not even be the clutch could be the pivot ball has broken of where the clutch fork sits i would be finding out actualy what has let go b4 blaming the mech or clutch company untill you pull the box out your really just guessing the problem
https://www.sau.com.au/forums/topic/130689-should-i-sue/#findComment-2419009
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
