  • Replies 43
One of the mechanics from my work once put a sticker on my car
"when i grow up i wanna be a V8"
...the funny thing is when i raced his GREAT V8 commodore .. his car was in my revision mirror before i changed to second!!!!
HAHAHAAHAHA OWNED!
https://www.sau.com.au/forums/topic/130706-get-a-v8/page/3/#findComment-2446084
yeah but you need to get a REAL MOTOR. like a 253 or something that does sik burnouts.
freekin tools. i hate tjhose guys
I actually just rebuild my brothers, and it does do good burnouts, but then again it runs flat tops, billet cam, shift kitted auto and my old mate the VL turbo diff...and he does not act like a bogan...plus it had as much power as my skyline, not bad for a 20 year old motor running a carbie...
Oh and those old 202 injected sucked cracker, the ECU's were shite, I changed back to carbie on my VK (the VK was the only one with the injected 202...)
If you don't have respect for MOST engines and cars, then you shouldn't md cars or own one...
https://www.sau.com.au/forums/topic/130706-get-a-v8/page/3/#findComment-2447652
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
