I can finally hear myself think in the car now. I had a cat back custom zorst fitted yesterday. Its a straight through system with a big centre res and large rear muff.
It read 88db at 5000rpm, driving around at 3000rpm it was down at 80db.
Prior to the change I drove in with a hold onto it, 118db at 5000rpm.
God dam its good to drive a quite car again!
https://www.sau.com.au/forums/topic/130741-ding-dong-the-noise-is-gone/
go the quite cars
my stock exhaust reads 74 db (quieter then a hyndai excel lol) with nismo cat as opposed to the apexi 3.5" all the way thru exhaust i got with the car with no cat converter which was im sure around 120+
i want my exhaust back tho for better flow/power, but law wont let me =(
that exhaust is guaranteed to get u defected, talking from experience
and silencer wont do shit... I had the remote control silencer on my system which could control the resonance/flow from inside the car and they still defected me and took me to EPA every time.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 馃檪  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
