G'day all,
First time ive popped into the VIC section!
My reason is im travelling up from good 'ol Hobart to collect my S2 R33 from Holfords motors in spotswood in a few weeks time. I'm just catching a midweek morning flight up to catch the spirit of tas home that night.
As i'm already pushing s*&t uphill to pay for the car, wondering whats the cheapest way to get from tullamarine airport to holfords, ie. bus to CBD first? i mean i wouldnt say no to a pickup :D
Cheers, Bart.
https://www.sau.com.au/forums/topic/130756-getting-from-airport-to-spotswood/
Whereis.com does acctually show the best way and it is relly easy because its all freeways...
but if you looking for a pick up, best to just come out and ask... maybe a small donation for a good samaritan could sway somebody?
:D
Convert the car to a boat less traffic :)
^^^^^^^^Seems everyone has a good idea for the quickest way, anybody done a wreckie and timed it, just teasing.
Cheers Andrew :O
:D
I'm more than willing to reimburse whatever it costs to come pick me up, only trouble is that i dont have an exact date for when the car will be ready, makes it difficult.
Just looking at the calender, it should be ready by the 29th / 30th, anybody free during either one of those mornings?? :O:D
Cheers, Bart.
Did I hear you say you'd be bringing your prospective taxi driver a case of Tasmania's finest brewery goodness as a good will gesture?
I'm sure someone may be able to find themselves running from Tulla to Spotswood during the week for you :laugh:
How much notice will you be able to give? If i have enough notice and no other commitments, i'll give you a lift. Just cover the Airport parking fee, etc, and i'll be happy to help out.
Plan to come to Tassie soon, for a nice week-long drive :), so i'm sure i'll need your help with something :).
Its domestic, hang at the McDonalds and drive up when he rings you. :)
Good offer though. :)
Plan to come to Tassie soon, for a nice week-long drive :D, so i'm sure i'll need your help with something :P.
I'll hopefully have a concrete date on monday arvo, id be able to give at least a weeks notice though. Im sure you can be taken on a tour of some of tassies more scenic areas, might give me a chance to take the new car for a decent length drive! You will have a PM monday evening :D
Cheers, Bart.
Just letting you know; on the weekend of the 25th, 26th and 27th i'll be in Shepparton, for SAU VIC's DECA day.
The weekend after (Sat. 2nd September) we have a SAU VIC members cruise (according to the SAU VIC events calender). You have unfortunately picked a busy period to pick up your car.
You mentioned 29th and 30th, these are work days and i will not be able to take time off work, so it all depending on what time you arrive.
Just let me know time and date, and i'll do my best :mad:
Might be a crazy idea but to save you some $$, wouldnt it be easier for someone to put it on the boat this side for you and collect it that end. You then save flights and the logistics of getting from the airport to Spotswood.
I am also assuming you can put a car on a boat with no passenger.
yeah good thinking, but im not sure you can put a car on the boat without a passenger, and id still need to get to devonport somehow to collect it ( i live in hobart). going to collect it is half the experience for me, but just trying to keep costs down.
Cheers, bart
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
