Hey,
Has anyone had a run with a HSV COUPE (GTS or GTO).
I was driving down Epping Road yesterday and had a Yellow HSV COUPE scream past me...
I can't tell which one it was as it was badged.
It was either the 255 kw or 300 KW job (probably the 255, hence the reason why he badged it).
Ohh did I mention he was on his P's. hahah Big bloke in the car (just looked funny). My first thought was he had been done for speeding and lost his license or somethoing like that.
So anyways had a little run and he couldn't pull away from me...
I also noticed when the corner got a little tight he couldn't hold the car in the lane and it started skipping (I guess you could say) into the next lane...Where moine just sat very flat on the road..
Regards
https://www.sau.com.au/forums/topic/13078-hsv-gts/
LOL.
I had a quick run with a GTS 300kw sedan one night.
I've got to say that it sounded really nice.
Anyway, the old 3rd gear got him :) I pulled away in the mid/high 3rd gear. I didn't scream away from him, but it was pulling away.
At that stage I only had a 3 inch exhaust, pod and 12psi boost.
J
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-247543
I've run a 255kW Clubsport R8, and I have to say it was pretty damned close - dead level actually, except after ~160 I pulled away (until I hit the limiter). Mind you, it didn't sound like it had the stock exhaust on it so maybe it had slightly more power than stock, maybe it didn't, I dunno.
I had a play with the 300kW Monaro a couple of months ago too. Unfortunately I was on the 'Blade though - the Skyline would've probably been more fun. Anyway, he had me level pegged in the corners (cos I'm a wuss) but on the straights it was like kicking a puppy :P The bloke was pretty cool, he gave me a bit of a wave and a smile, and even kicked it out a little bit as he took his turnoff... wicked :(
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-248130
At a track day a while back, on the twisty bits I was all over the GTO's. Had more corner speed and could brake a lot later than them. There were about 3 of them. Coming on the straight though, they've got torque and plenty of it.
PFC should fix that problem now.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-248295
  • 5 months later...
Originally posted by Jay95R33
LOL.
Anyway, the old 3rd gear got him :(  I pulled away in the mid/high 3rd gear.  I didn't scream away from him, but it was pulling away.
J
He He so the old 3rd eh ... funny about that as thats usually when my LS1 does its best work
I don't usually get a look in in 1st gear usually start to match em in 2nd and 3rd is when it all happens for me the gen 111's start to hunt em down.
The Skyline is a very nice car guys so is the humble Commie, its been a learning experience perusing your Forums.
Cheers :burnout:
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-549242
Originally posted by SS Enforcer
He He  so the old 3rd gear eh ... funny about that as thats usually when my LS1 does its best work
I don't usually get a look in in 1st gear usually start to match em in 2nd and 3rd is when it all happens for me the gen 111's start to rrally fire up.
Cheers :burnout:
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-549250
Could someone please explain to me why Mel always gets picked on by Commodores. Wollongong was a great example last friday night. We were just out for a cruise after dinner at Stanwell Park and looking for a Mobil servo down there and all we got was clowns after a piece of her. Look out the day she decides enough is enough,,,theres gonna be some very pissed off aussie muscle. Then again,,,I should stop having 3 beers at dinner,,,cause I won't put up with that crap.
Neil.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-550115
beware of a black commy monaro getting around sydney as the last time i was at 'the creek' there was one running around a flat 12 or high 11 (around this - my memory fails me at times). either way it was quicker than any skyline was on that particular night
it looked quite std but didn't sound it.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-550837
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
