Hey,
Has anyone had a run with a HSV COUPE (GTS or GTO).
I was driving down Epping Road yesterday and had a Yellow HSV COUPE scream past me...
I can't tell which one it was as it was badged.
It was either the 255 kw or 300 KW job (probably the 255, hence the reason why he badged it).
Ohh did I mention he was on his P's. hahah Big bloke in the car (just looked funny). My first thought was he had been done for speeding and lost his license or somethoing like that.
So anyways had a little run and he couldn't pull away from me...
I also noticed when the corner got a little tight he couldn't hold the car in the lane and it started skipping (I guess you could say) into the next lane...Where moine just sat very flat on the road..
Regards
https://www.sau.com.au/forums/topic/13078-hsv-gts/
LOL.
I had a quick run with a GTS 300kw sedan one night.
I've got to say that it sounded really nice.
Anyway, the old 3rd gear got him :) I pulled away in the mid/high 3rd gear. I didn't scream away from him, but it was pulling away.
At that stage I only had a 3 inch exhaust, pod and 12psi boost.
J
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-247543
I've run a 255kW Clubsport R8, and I have to say it was pretty damned close - dead level actually, except after ~160 I pulled away (until I hit the limiter). Mind you, it didn't sound like it had the stock exhaust on it so maybe it had slightly more power than stock, maybe it didn't, I dunno.
I had a play with the 300kW Monaro a couple of months ago too. Unfortunately I was on the 'Blade though - the Skyline would've probably been more fun. Anyway, he had me level pegged in the corners (cos I'm a wuss) but on the straights it was like kicking a puppy :P The bloke was pretty cool, he gave me a bit of a wave and a smile, and even kicked it out a little bit as he took his turnoff... wicked :(
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-248130
At a track day a while back, on the twisty bits I was all over the GTO's. Had more corner speed and could brake a lot later than them. There were about 3 of them. Coming on the straight though, they've got torque and plenty of it.
PFC should fix that problem now.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-248295
  • 5 months later...
Originally posted by Jay95R33
LOL.
Anyway, the old 3rd gear got him :(  I pulled away in the mid/high 3rd gear.  I didn't scream away from him, but it was pulling away.
J
He He so the old 3rd eh ... funny about that as thats usually when my LS1 does its best work
I don't usually get a look in in 1st gear usually start to match em in 2nd and 3rd is when it all happens for me the gen 111's start to hunt em down.
The Skyline is a very nice car guys so is the humble Commie, its been a learning experience perusing your Forums.
Cheers :burnout:
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-549242
Originally posted by SS Enforcer
He He  so the old 3rd gear eh ... funny about that as thats usually when my LS1 does its best work
I don't usually get a look in in 1st gear usually start to match em in 2nd and 3rd is when it all happens for me the gen 111's start to rrally fire up.
Cheers :burnout:
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-549250
Could someone please explain to me why Mel always gets picked on by Commodores. Wollongong was a great example last friday night. We were just out for a cruise after dinner at Stanwell Park and looking for a Mobil servo down there and all we got was clowns after a piece of her. Look out the day she decides enough is enough,,,theres gonna be some very pissed off aussie muscle. Then again,,,I should stop having 3 beers at dinner,,,cause I won't put up with that crap.
Neil.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-550115
beware of a black commy monaro getting around sydney as the last time i was at 'the creek' there was one running around a flat 12 or high 11 (around this - my memory fails me at times). either way it was quicker than any skyline was on that particular night
it looked quite std but didn't sound it.
https://www.sau.com.au/forums/topic/13078-hsv-gts/#findComment-550837
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
