OK so here's the story
previous setup:
- stock auto trans with trannie cooler
- rb20det with rb25 turbo
car would stall to 1800rpm at the strip and generate about -5psi manifold pressure.. when taking off its lag city
then gear changes take about 1-2sec
i ran a 14.7 @ 98mph with a 60' of 2.5sec
new setup:
- 2800rpm high-stall --> from MV automatics
- stage 2 shift kit --> from MV automatics
now the car can stall to 3200rpm and should be able to generate about +5psi manifold pressure!
i have not tested this yet as i have just got the car back and have not driven on my own..
the shift kit drives really nicely...
Low rpm shifts are almost normal but high rpm shifts are very firm.. pretty much instantaneous!
hoping to drop the 60' time to 2.0sec and instant shift changes with this setup and looking at running low 14s...
will post a more thorough review below in the next few days...
GO THE AUTO!!!
cheers,
Warren
i bought the items from MV automatics and they sent to brisbane. i had them instaleld up here in brisbane and am sending my old items back
for price, contact MV automatics. i'm not affiliated with them so don't want to quote prices on their behalf...
apparently stage 1 shift kit is for towing, and is not really performance orientated
the stage 2 kit is for performance shifts
the stage 3 is a fully manualised valve body (using stock shifter to change gears) and is more for engine conversions apparently
Hmm sounds interesting.
Might get my hands on one.
What power are you on at the moment?
Just worried about drivability compared to stock.
Is there a difference between gear changes? Very harsh or just similar to stock?
Would you have MV Automatics details?
as i said, i have not realyl had a chance to give the car a good drive yet, but on initial impressions...
low rpm gear changes aren't to bad. sometimes first to second clunks but its not too jerky at all.. still instantaneous
mid rpm gear changes are very clean and not jerky
high rpm gear changes have not been done yet, but the mechanic test drove the car and said that it chirps from first to second :)
MV details:
Mike at MV AUTOMATICS
1 Stirling Rd Blackwood SA 5051 (08) 8370 0430
ok i have now given the car a good lot of driving...
changes from first to second are a bit harsher than normal. sometime at low speeds you can feel a bit of a jolt/clunk as it changes gears..
other gear changes are fine
changes are mid to high rpm are very smooth :/
flat out first to second does chirp the wheels too!
obviously all the gear changes are now instantaneous...
as for the stally...
i can get it to about 3300rpm holding the brake and handbrake. this gives my 6psi :/ after than i start to wheelspin...
this is going to make a HUGE different at the drags adn will defiately drop my 60' times half a second and hopefully my ET by 0.7sec or so...
hrrrmmm...sounds good! I'll definately be keeping my eye on this thread as im considering something similare for the 33...
WazR32GTSt just a side question:
When taking it for a run on the strip do you leave it in D or start off in 1st and go through the gears???
  • 1 month later...
Good stuff Wazz..
Be sure to let us know how much better it runs down the strip.
It looks as the stock convertor will suit the rb30 well. 1800rpm or so its making what ever boost I throw at it and with a gt30 bolted on the side will no doubt be making some reasonable boost at that rpm also.
Should be good. Can't wait to flog this manual off. :P
for those who are after the prices and details on the valve bodies (shift kits) and torque converters go to this thread
http://www.skylinesaustralia.com/forums/in...showtopic=62854
My 33 has run 13.2's with a failing diff, and Tein suspension (way too hard for drags).
I got the best time manually selecting gears rather than leaving it in drive, but I also have a PFC so this may make a slight difference to my shift points.
cubes, just think how jucy 10+psi would be at 3000rpm with a nice high-stall on the rb30!
lol yep.. at the moment its making around 100rwkw at 2000rpm, 2500rpm 130rwkw and 3000rpm 164rwkw. :P
light throttle cruising.. How do you find the highstall? does it still feel fairly tight? Fuel economy any changes?
I've never had a high stall so when I hear high stall i think of the oldschool v8's u see cruising around that when taking off even on light throttle instantly flick to high rev's and take off even though they are only limping it around. They can't just give it light throttle and cruise off sounding normalish. If that makes sense. :no:
Would be awesome to check out an incar vid of the speedo tacho with you just cruising around.. maybe a little bit of a hard throttle blip off the mark with out stalling it up and maybe with stalling it up also. :)
Just to wet my appetite. Thats if your able to do so.
I sure will be doing a before and after vid.. before with manual.. after with the rb30.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
