Im selling my 1989 r32 gts 4 door
engine is an rb20de, has done 150xxxkms, auto, the car is silver and the body is in pretty good nik.
The car is stock as a block, i only bought some rims for it and an alarm, been service a fair amount.
$5000 frim
pm if interested or have any questions
may be interested in a swap
located in S.A.(hills area)
Edited by talism
https://www.sau.com.au/forums/topic/130825-sold/
So are you negotiable at all on the price?? I could be interested, but a bit out of the price range, as I was really looking for something with no engine, as I crashed my 32 four door
https://www.sau.com.au/forums/topic/130825-sold/#findComment-2459466
sorry buddy i brought this one.
CHris...
https://www.sau.com.au/forums/topic/130825-sold/#findComment-2459566
    • My son saw this Porsche 904 in Yodoyabashi in Osaka, not sure if it's the plastic or fibreglass version 767605763.559358.mp4
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
