Rolling Bearings Co Pty Ltd
1/ 1880 Hume Hwy Campbellfield VIC 3061
ph: (03) 9357 9955
rbc arent cheap from my exp :mad:
ummm first of all, why would you want CHEAP bearings, i personally wouldnt trust them..
What area are you from?
RBC has a few branches.
You could also try bearing wholesalers. I know the guys in the moorabbin store :stupid: cheap cheap for me
i live close the cambellfield... i might check it out first.. does the moorabin store able to ship the parts and how much did you get yours for? I'm looking for NSK parts so i think all NSK bearings perform the same and just difference places sells them at different prices.
you want low quality bearings
be prepared to have a head smash 24 valves.
Cost should not be an issue for idler/tensioners
true that but the prices vary so much from 100ish for NSK ones to 200ish for genuine ones. if they are of identical quality it would be nice to save some $$. a few people here are using NSK ones with no probs, i guess because they havent clocked the k's on em yet to find out. ah what a head scratch!!
they aren't gonna cost 200 :laugh:
RBC charge about $120 for the pair as complete units ready to bolt in. They are standard NSK which are the Nissan OEM bearing so just call with the stock part number. There is a decent number of threads on here that will have the number listed so search. I've known of others who have pressed the bearing out and just replaced the bearing to have it fail about 5000km later.
Make sure you get new grade 8 or 12 bolts. Young guy that lives nearby had mild bolts installed by the mechanic and one failed through fatigue in a couple of hundres kays. Pistons survived but new valves all around.
Chris, this is the whole pulley for reason stated above.
I found RBC helpful and a good fair price.
thanks Geoff...hope ur feeling better mate. I still have a front grille for you!
Yeah good point...I took off some pullies the otherday and thought they were on the way out...$120 for NSK is not bad for the whole unit. I thought they were just talking about bearings.
on that note I broke off one of the tensioner screws yesterday...must have failed for something just sheered right off..lol bought some new bolts but need to get the old thread out.
I'm also trying to work out an easy way to take off the damn PS belt...looks like the lock bolt is the one just above the tension bit...bitch to get at...give it another go next weekend.
Might as well do the bearings also while everything is out...so what are the stock part nos...?
yellow pages is your friend, we get stuff delivered from bearing wholesalers, but we have an account with them at work etc. they could possibly courrier then out, i do not know ... best to look it up in the white pages there may be a store close to you :rofl:
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
