I was wondering if anyone can give me some advice what i should do(worse when hot than cold)
Here is a list of things i have already done
changed timing belt
new spark plugs
got injectors serviced
cleaned the air flow meter
tried coils of another car that has no problems
tried another igniter from the same car as above
checked engine temp sensor
checked for errors on the engine management light
reset engine management
checked for start signal at the engine management
cleaned AAC valve
checked that the TPS works
PLEASE help i have run out of ideas
https://www.sau.com.au/forums/topic/130847-hard-to-start-rb20det/
According to the workshop manual:
Try with temp sensor disconnected
Check temp sensor resistance value - 0.3k ohms @ 80C
Check temp sensor output voltage - (pin 1 to earth) 1V @ 80C
Check fuel pressure - remove vacuum hose from regulator, or clamp return line.
Cranking speed OK?
Cranking speed OK?
Yeah i tried that and it was OK as per the manual.So i thought about this and i tried it(MY OLD MAN SHOWED ME THIS A FEW YEARS AGO ).I just tried to adjust the timing going on idle smoothness and speed and found a point where it idled really smooth( a fair bit retarded compared to where it was) at around 800rpm or so and now it starts really well.I didnt check it with the timing light but i did get a few mechanics to check the timing before i did what i did and all said it was fine how i set it using a timing light.strange ah :)
