Here is a graph from my last dyno tune...
My A/F ratio is a little high and i'm getting high knock levels at high rpm...
On a post earlier someone suggested that it was my walbro 255lph fuel pump that was giving out and not flowing enough fuel...
However, I'm still using a sII rb25det afm and making 371hp...
Would this be a problem causing my high knock levels or the fuel pump?
I turned up the fuel pressure to 50psi and my injector duty cycle is set at 87.0% on 550cc injectors.
https://www.sau.com.au/forums/topic/130868-afm-questions/
Dude I've figured out now that you are in the US somewhere (probaby Georgia) but you should state that since 95% of us are in Australia and use different methods of working out horsepower - we actually prefer kilowatts but anyway...
So to your question; Yes the AFM should be well and truly maxed out. What ECU are you using? That said we have been using these walbro's and they are shit. You are right in the area where flow becomes a real problem.
Here's an easy test for you.
Put car on dyno.
Take off fuel return line and point into a bucket or tin.
Run the car up at full power.
If the return flow reduces to a trickle or even worse stops completely (as it did mine) take the pump out and sell it to someone who has less power than you.
This test is cheaper than replacing your pump just in case and since we don't know what ECU you have or the tuner's methods we can't comment on the afm really.
https://www.sau.com.au/forums/topic/130868-afm-questions/#findComment-2422352
running 50psi base rail pressure? Do i read that correctly?
Thats astronomically high for 550cc injectors that should pump out (in your terms) over 450rwhp on the stock 38psi base.
I would say the fuel pump is not working, remembering that walbro's are nothing but a waste of money.
Make sure the pump is seeing the correct voltage.
If it is, rip it out and put a bosch/nismo pump in there and be done with it
https://www.sau.com.au/forums/topic/130868-afm-questions/#findComment-2422401
Yesterday I hardwired the fuel pump to the battery... It's now recieving 13. + volts and I'm still getting high knock levels in the high rpms..
I'm using a PFC and my car was tuned at a certified excel tuner facility..
So are we saying that I could be getting high knock levels because my afm is being over flowed? The reading on my pfc is saying my afm is seeing 5115mv or something along those lines...
So it looks like i'm getting a new fuel pump... prolly not the nismo because it's twice as much as a bosch pump... what do you guys recommend? I see a lot of people on here using 040 and the 044...
https://www.sau.com.au/forums/topic/130868-afm-questions/#findComment-2424293
yep sounds good mate....practically everyone runs a bosch these days...they do the trick very nicely.
Yes your airflow meter is out of range for the airflow your seeing. You need to get a z32 or q45 to cope. What rpm is it showing 5v?
https://www.sau.com.au/forums/topic/130868-afm-questions/#findComment-2424390
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
