Hello,
I have a set of BRAND NEW Garrett 707160-5 Turbos(Equivalent to HKS2530's) Rated at 350hp each with
supporting modes, actuators attached.
These are a direct bolt on replacement on any GTR.
I am asking $2750 for both and am able to deliver for free in Melb. Metropolitan Areas.
PM or Email me if anyone is interested.
Thanks
Tekin :mad:
SOLD SOLD SOLD SOLD SOLD SOLD SOLD
https://www.sau.com.au/forums/topic/130882-garrett-turbos/
Hello,
Thanks
Tekin :)
PRICE DROP $2700 :laugh:
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2422439
Hello,
Thanks
Tekin :D
PRICE DROP $2650.00 :)
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2423537
$2550 no more no less :O
For an extra $300 you can have a RB26 Manifold set :) (stainless Steel)Tune Agent Low Mount
Come on guys $2850 for both sets, Manifold and Turbos.
All Brand New in Boxes....Expect to pay over 3kPlus from Suppliers.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429399
as i now have no licence i was thinking of pulling of turbos and replacing?would these turbos be ok with everything stock besides ur usual exhaust filter mods.... how laggy are they????
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429611
Lag is slighly higher than the factory units.
You need a set of hks dump pipes to get them to spool up quicker, and might need new braided oil lines,
smaller than original to protect the turbo's from over supply(These are ball-bearing and need less oil through them).
If you are concerned about the lag, get a D-Jetro Power fc set up and lag will be in the past.
Slight mods such as air intake and exhaust(3") would have a great affect when these are installed.
You would need to get it tuned after fitting.You need to tighten the actuators to set the boost up if you do not want to use a boost controller.Do a search to see results on these turbo's.
Hope I have been some help.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2429654
For an extra $300 you can have a RB26 Manifold set :P (stainless Steel)Tune Agent Low Mount
These come with a waranty guys.......$2850 with manifolds , all new.
Expect to pay $3300 plus.....come on.
You can pick up too...how good is that.
Cheers :)
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2433415
Cheers :)
Manifolds come with gasket sets too.
Need to sell by Friday next week...or taking them off the market.
https://www.sau.com.au/forums/topic/130882-garrett-turbos/#findComment-2437074
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
