  • Replies 245
Posted Images
You're in the list, justin911
Thank's predator, first post updated. I checked with DBA catalogue, R32/R33/R34 GTSt all used part no 908 so they're all same.
marz13, as I said it's my estimate but I could be wrong. I am basing my estimate from the price I was given for front R33 slot and rear. But those ones are R33 gtst prices. For R32 GTR which uses 324mm it may be a lot higher. However for comparison, a mate of mine got his front slot R33 gtst rotor for $310 a pair, while I am offered $275 plus GST (or about $302.5 incl GST) for fronts. This does not include group buy discount, so if 20-25% less a pair of front R33 gtst is between $226 to $242 a pair.
r33 gts-t = 296mm, Z32/r32 gts-t = 280mm - Fronts
rears are the same.
I'm keen on a set of 280mm slotted/dimpled depending on the price.
I'll put you in as well fly510
put me down for a pair of front slotted rotors for r33 gtst. but it does depend when the gb closes... its looking good so far... if it starts to look like more than a fortnight from now i may get some rears too...
Freddy Krugger, list updated.
GB is looking good. The guy at RDA told me that since they have branch in every city, they may organise to drop off the discs to their branches so ppl outside Melbourne can pickup at their nearest city. Otherwise he hasn't told me yet the exact price but for a local delivery should be reasonably cheap. I had my set bought on ebay shipped for $15~30 from memory, and that was from NSW to VIC.
Dezz, the prices so far I had is on the 1st post, just reduce by 20~25% off to get the group buy price. Hard to get exact at the moment as I am still opening this EOI list until end of the week to get the maximum qty possible, then we'll see how much RDA is willing to give discounts. I had asked him a few questions about all the prices but so far he hasn't given me a full RRP list yet.
2face - you're in
Shane, I'm sure no probs as it's in the Nissan-D.xls list in the first post. Under S series 200SX, S15, part no 909 is the same for S14
Just this week I began hearing the familiar and dreaded sound of worn pads. Bastard thing wants MORE money.....it's worse than having a teenage kid!! ;o))
Depending on when the group buy ends, you could put me down for a set of slotted fronts (possibly slotted rears as well). Will be getting the disc runouts checked tomorrow.
Cheers,
Mike
Hi,
Can u change my order to just slotted rotors front and rear for R32 GTR,
Thanks
prelude :
no problem
r33fourdoor :
i'll put you in as 1 pair fronts.
i'm leaving this eoi thread til saturday/sunday then i'll bring the approximate numbers to RDA and see if we can get the 25%off or even better but I doubt so, 25% pretty darn good already. then i'll start to finalise orders the following week and organise payments and logistics, as well as allowing more ppl to jump onto the bandwagon.
Can you pm me the expected pricing for front and rear slotted rotors for HCR32 please.
Blitz, std slotted price are on first post of this thread. Most likely R32 also uses the same dimension with R33 so it'll be about $300 for the front pairs and $190 for the rear. Add this up $490 for a set of 4, minus 20-25% discount you can expect roughly in the range of $370-390.
There's a Nissan D.xls spreadsheet on first post, you can have a look if your dimension is the same with R33, then that price on 1st post will be spot on.
Guest
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
