if u are talking about a day permit, u can get the from the dept of transport, which allows you to drive the car where ever between the hours in which the permit starts and ends.
if u arent driving very far, then it should be ok but if u are planning on constantly driving round the more chances of u getting picked on i guess. like i drove my car from maroochydore to caloundra this morning with no exhuast on it, so it oculd get fiuxed, but if i kept driving round with no exhuast then i woulda got picked up for sure. by the way RB with no exhuast = spooling loudly.... :mad:
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2422227
85URK you make it sound too easy!
Firstly you have to organise third party insurance.
Then on the appliction form it states-
If the vehicle does not comply with the transport operations (Road Use Management - Vehicle standards and Safety) Regulation 1999 a Police Permit must be obtained
Haha that would have been good to see the 33 screaming off it's tits :mad:
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2422255
if u arent driving very far, then it should be ok but if u are planning on constantly driving round the more chances of u getting picked on i guess. like i drove my car from maroochydore to caloundra this morning with no exhuast on it, so it oculd get fiuxed, but if i kept driving round with no exhuast then i woulda got picked up for sure. by the way RB with no exhuast = spooling loudly.... :D
SR with no exhaust is very loud too... :)
Haha that would have been good to see the 33 screaming off it's tits :)
I have actually done this my self twice.... Third party insurance... which one (compulsary or the non-compulsary one)? as long as you dont plan to run into someone you should be safe (ie. drive like a slow grandma, be extra careful and dont do stupid things). If your only going to a very short distance, you should be fine as long as you get the one day permit thing.
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2423356
Yeah what ever insurance is the cheapest.
So did you not have to apply for a police permit? What mods did your car have? Was it inspected?
I'll probably look at getting a permit to last around a week.. Whats the go with trade plates? Can they be used to get a vehicle from where it's stored to a workshop?
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2423432
Drift limo if your after a Day Permit, you'll need as you said a above, a Police one. Transport won’t give them out on non-complied cars in Queensland.
Obviously you get these ones from the Police station.. I've seen your car they will tell you to tow it, lol.
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2424401
I've used trade plates on non complied cars to get them around, as I said above transport won't issue pass's on imports with no compliance/ADR plates.
They inspected my bog stock n/a R32 4 door when I went in to get a day pass too, which had all been ADR'd.
Edited by Nismo_Boy
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2424403
relistically i think almost evey mod to my car is a defect. you'd be surprised what's illegal. every mod should really have a mod plate & emissions shouldn't be harmed in any way. Just dont do anything to stand out where u know there is a police presence.
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2424669
Haha there goes that idea then. See I'm making an effort to abide by the rules, they just make it too hard sometimes..
Hopefully who ever does the tune are lax with their trade plates.
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2425505
Didnt get a police permit, but I got a day permit from DOT for it... My cars are always standard (sif list all the mods out on the internet).... It was inspected and complied tho (sorry I thought you car is already complied).
Using a trade plate Nismo_Boy already answered it. :P
https://www.sau.com.au/forums/topic/130889-police-permits/#findComment-2426131
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
