Hi, Im looking to purchase a cusco diff for my car but i would just like some advice first. (NISSAN SKYLINE R33 GTS-t)
1) RS or MZ, my car is primaraly for the street but i do on odd occasions race it. I understand the RS is better for the street but what are the main disadvantages of 1 over the other in terms of driving comfort/safety/performance
2) 1, 1.5 way adjustable?
From what i understood, the cusco diffs can be adjusted for 1 or 1.5 way without extra parts, so why are they being sold as seperate products?
3) I am concerned about the shuddering of a 1.5way diff. Is there any advantage of 1.5way over 1way (except for drifting). If i get a 1way, will it shudder? If i get the 1.5way, will the shuddering eventually go away after a couple of gran kms driving and a few oil changes? Is say a KAZ one better than CUSCO in terms of shuddering?
thanx ppl
https://www.sau.com.au/forums/topic/130896-question-of-wat-diff-to-get/
According to their website RS will engage more smoothly, which is what you want on the street. On the track, response time counts more and racers don't care if the diff clunks with sudden engagement.
I would get a 1.5 way diff for the street, personally.
Shuddering I'm not sure about, but I expect it would be less of an issue with the RS diff as the springs absorb the initial shock. I've heard the KAAZ diff shudders like buggery when new, but once broken in they are much better.
RS would probably be the go. Cusco recommend it if it's street driven (less harsh clutch engagement etc.)
I would suggest 1.5-way for overall useability/goodness. If you plan on going anywhere near a drift track, 1-way's are near useless.
i don't know, but all the new-ish kaaz 1.5 and 2-way diffs i've seen shudder like a bitch, i would avoid kaaz diff's if you are after something less-harsh.
Cusco are ment to be good, but i've never driven one. It's almost impossible to avoid some degree of harsh engagement with mech diffs, especially when brand new...
i personaly prefer nismo.
they are oldschool but WORK and dont let the whole of woolworths carpark know you have a aftermarket diff.
ive driven cars with kaas,cusco 2ways and they are crazy harsh. i could sware the driveshafts were gonna come through the floor. just way to harsh and for circut racing it would be way to taily. great for drift but just no fun on the street,well after a few hours anyway lol
1way is only good for front wheel drives. as it only locks up in 1 direction. perfect for gtr's in the front.
for the street a 1 way is really what alot of people want but dont realise it. whats the point of locking up the rears on deceleration?
1.5way is more suited for people who can drive. its a circut racing style diff. it offers good lockup on aceleration but also offers a slight lockup on decel/bracking to stop one rear locking up under braking. it oes a good job of it to ;)
2way (depending on the brand) is a drift diff esentally. gives crazy lockup in both directions. quite scary in the rain and i woulnt recomend it if you have a girlfriend, (ones that arnt into cars that is lol) coz they will think your car is broken, with all the clunking and banging :P
with any of theses using a "friction modifier addative" is needed to smoth out the clunking.
either the holden one or the nismo one works well
hope that helps
lol, i know what you mean. My passenger side arm rest handle is broken thanks to this....
i've driven in the wet before in cars with 2-ways, and also in cars with fully locked. The fully locked feels safer because there is no sudden engagement, but they are both safe enough if you drive the car sensibly.
Edited by MerlinTheHapyPig
Have decided that since i mostly use my car for street purposes and hardly ever for drift that i will have my diff rebuilt and made tight.
Wat put me off a lot was the clunking of the mech diff, i'm a lover of comfort and i always have girls in the car so i dont want them to start hating my car, lol. Plus its a cheaper option. Diff rebuilds are about 800 - 1000 yea?
So is a 2 way diff the same as a locked diff?
Do circuit cars only use 1.5 or some use 2?
Why is 2 way such a good drift diff and why is 1 way no good? Afterall, when youre going through a corner and dump the clutch, your accelerating... Is it because youre on and off the throttle all the time for example one point through the corner youre acclerating (1 way spins both) and then you back of a bit (in which 1 way and 1.5 way would revert to spinning one wheel???) and then back on, (1 way back on)...??
Edited by 180bfj20det
Haven't heard of anyone rebuilding a viscous LSD. The LSD unit is hermetically sealed so you probably have to cut it to get it open. And nobody would bother rebuilding one they all go to clutch LSDs if you want proper LSD action. You'd be better off finding someone with a second hand GTR diff in good condition, it will probably be more compliant than an aftermarket diff. It'll probably cost the same tho :)
Read this article: http://en.wikipedia.org/wiki/Limited_slip_differential
I read the link before you posted it, it doesnt really answer my question. A locker will lock both up when decelerating hard (same as 2 way) will hook both up all the time when accelerating (like all lsd hopefully) but a locker wont go around a corner without letting you know about it....will a 2 way be also a bitch like a locker and if so, why not just weld your diff??
My Kazz 1.5 way took about two months and two oil changes to be completly quite, but now, it's perfect.
You can still hear it when the oil is cold, but after that, it's fine.
You figure out how to reduce any noises by different styles in carpark driving.
It's quite, it's fine to live with (providing you put the right oil in it) and it locks up hard when accelerating.
it's perfect for what I want.
I found that with my stock diff, it would only spin two wheels in second gear, otherwise it was one wheel. with the 1.5 way Kaaz, it spins both, but the threshold of spinning is much higher as both wheels need to spin.
This is great on the track and the skid pan.
It's much more predicatable and controllable then the stock diff that would sometimes lock up and sometimes not.
BASS OUT
A 2-way won't be as bad as a locker, but around tight corners and parking it'll still let you know about it. I haven't driven a 2-way but by the sounds of things it's largely impractical for the street.
I had a mini-spool in my last car, and although the ability to get sideways was awesome if you're at all serious about decent handling you'd be silly to get one. Off-throttle it understeers and on-throttle it oversteers, you need a delicate balancing act to go around a corner quickly. Which is fun in itself, but requires a lot of concentration because if you overcook a corner your first instinct is to brake, which makes you understeer more.
I agree with this 100%
Driven cars with Nismo, Cusco, KAAZ and ATS lsd's ( all 1.5 ) and the Nismo was by far the most user friendly diff of the lot.
I had an ATS 1.5 LSD in my 32 and yeah, they do quiet down a bit after a long time with the use of a friction modifyer, and yeah you do learn to drive the car a certain way so as not to tell everyone that you've got an LSD. But if I was to do it again, I would buy a Nismo ( or if I had the money I would try an ATS Carbon LSD :rofl: ) http://www.a-t-s-usa.com/ats-products/lsd-carbon.shtml
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
