Ok heres my dilemma. ive got a 95 240 with a 97 ECR33 RB25DET swap. i just did the following modifications, Greddy intake plenum, infinity Q45 throttle body, FMIC, Greddy Type RS BOV, and walboro 255 fuel pump. When i cranked the car up white smoak poured out of the exhaust constantly while at idle and when the throttle was engaged. it smells like antifreeze but where the hell is it coming from. i need to get my car back running so any help on figuring out my problem will be greatly appreciated. thanks.
https://www.sau.com.au/forums/topic/130901-smoking-rb25det/
ok so i went outside today and cranked the car and cheked the radiator to see what happened. at idle (which was 2000 today) a small amount of white smoke came from the exhaust. after accelerating lots of white smoke came out and black shit blew out of the exhaust also the coolant level dropped in the radiator. so im assuming its a headgasket problem correct?
https://www.sau.com.au/forums/topic/130901-smoking-rb25det/#findComment-2424478
ok so now that ive figured out its a headgasket problem what size gasket should i go with. ive got a place thats goin to do the work for me i just need to get the parts. i was looking at a 1.2 mm cosmetic or a 1.0mm greddy with ARP headstuds. what will be the best.
https://www.sau.com.au/forums/topic/130901-smoking-rb25det/#findComment-2425541
right now im running stock until i can get some more cash. and as for compression im not sure when its all said and done maybe in the 8.5:1 to 9:1. as for aftermarket turbo ive looked at alot and right now am looking at a T-67.
https://www.sau.com.au/forums/topic/130901-smoking-rb25det/#findComment-2432045
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
