When driving my skyline (R32 RB20DET Manual), as soon as i reached
the 2100rpm mark on acceleration, it sort of feels like its holding back but it jerks
forward like it doesn't know what it wants to do. When i put my foot down to
accelerate its ok, once past 2100rpm, not a problem.
https://www.sau.com.au/forums/topic/130905-car-is-hesitating-at-2100rpm/
are you still running the standard fuel pump? if so sounds like it is on its way out. from what i can read i beleve u have a bit of fuel surge as the fuel pump can no longer pump fuel fast enough, giving u that hesitation.
ive done plugs, last owner changed coil packs and now has the current 1s taped up and mine does the hesitating thing..... ive had it for 2 years, still does it, maybe the fuel pump..... but if it was on its way out, should of gone by now
I've now got a GTR pump in mine and that hasn't fixed the problem.
This came up a few times , so do a search on what it could be.
I think AFM , Injectors followed by OXY Sensors was the discussion
on those topics.
sounds like an AFM problem! car sort of bunny hops like its got no fuel then goes again... clean your AFM with carby cleaner. if that dont work try the AFM soldering there a DIYS here some were. or buy another 1. i just brought a used 1 and fixed my problem.
hope this helps
Its a R32 Skyline, RB20DET.
I did clean my AFM with carby cleaner and did the re-solder on it.
I think i might clean it out with the carby clearner again.
I'm running coilpacks, havn't got leads.
Coil pack normally has troubles at high revs.Put injector cleaner into the fuel tank,
see if that might fix it.Changing the afm to find out it did not fix the problem would hurt your pocket.
Any one got a working AFM to lend to see if thats the problem?
Where abouts are you?
