Hey guys
New to skylines (been driving a 300ZX Z31 for the last couple of years). I'm about to purchase a 96 R33 skyline GTS-T M Spec.
I went to have a look at it today, chassis was in perfect condition, however 2 things we picked up on.
First - turbo didn't seem to pull as much as other R33's we had driven, there was however a lot of induction noise (what we think was induction). The car only had a pod filter on, loosely fitted. So we suspect it was that. I put a deposit down then decided to go for another drive, as I pulled out of the car lot, the car died and wouldn't rev. Letting the car idle, it was surging up and down and running rough. The car dealer said it was nothing to worry about - was probably the mass air flow sensor needing resetting (how do u reset that lol?) or a coil pack and would be fixed by the time I pick the vehicle up.
Is this something I should be worrying about or something I need to look further into? Could this be related to why the turbo wasn't pulling? I know a fair bit about cars, and nissans in particular but turbo's are new to me!
So help me out guys! help ease me into the skyline world!
The only other problem was the suspension (way to hard - bouncing all of the place) but easy to fix that one I think.
Car has VERY low k's and price is right.
Cheers ppl,
Matt
https://www.sau.com.au/forums/topic/130945-new-to-skylines-quick-question/
yeah I had my mate with me who owns a skyline but he wasnt sure either, my mechanic couldn't make it out with me but we will go and have a deeper look next weekend, i thought i'd jsut see if it was something common that people knew about or something - put my mind at rest as the rest of the car is gorgeous lol
Surging caused by an air leak after the AFM (Air Flow Meter), so if the pod is loose it wont have any effect. But if anything is loose after the AFM, problems will start. With pod filter it is normal to get heaps of induction noise.....
Air leak could be highly likely for lack of power as all that boost that is being created is leaking out, not to mention the car will be out of tune as the AFM tells it how much air is entering the system, ECU with leak getting incorrect reading and will be running it too rich. The car's ECU must have gone to limp home mode for it not to rev!!!!
Best of luck with your potential skyline, if you were down on the gold coast i would happily go check it out for you.. :laugh:
Edited by 12DFY
off the topic, if a 96 model car has a very LOW mileage, u should know what is going on. dont u think its a bit sus that a lot of the imports are around 60000kms mark????mileages doesnt mean anything.
as for the turbo, if the car is runnin a pod in the engine bay, it will directly suck in all the hot air and hence the inlet temp will be quite high. thats why it doesnt pull as hard. this is the best case scenario.
Edited by frankxinyu
I would not use RACQ to check it over...
Id use a skyline buff...
Take the car to one of the workshops in the topic below...
http://www.skylinesaustralia.com/forums/in...howtopic=130753
that was only a general suggestion.oh and by the way some racq mechanics have worked on skylines.if you arent sure of the car get it looked at, that was the point.
Hey will be more than happy to check over it, you can tell if the km's are genuine by looking at some telltale signs, suspension bushes etc etc.
I am a fitter and turner, marine fitter/engineer and an armourer who has done nothing but play with my two skylines for the past few years. Not a mechanic on paper as of yet but am thinking of bridging the gap to get that ticket as well.
Will be more than happy to check it out for you mate, if they give us enough time I can compression test and all that crud as well. I recently rebuilt my motor, gearbox, diff etc so I know my way around the 33 quite well.
Hate to see people get ripped so am more than happy to share the knowledge!!
Edited by 12DFY
Oh and by the way some racq mechanics have worked on skylines.
Maby so, they also work on shop riders. But its a bit like going to Clive Peters and asking advice about PC's and technoligy then asking the same person about toasters & kettles...
Use a specialist in that industry or on that topic...
Id go straight to those who know exactally what their looking at... Give me a RB with an issue and ill find a solution...
BTW> RACQ are more about road worth's and safty cert's rather than mechanical advice...
racq are f**kwits
use these guys ..they actually no what there doing https:state roads
150 point check for $179 ..even measure paint thickness for previous repairs or crash damage
racq are ignorant fools...ie: HICAS NOT WORKING .. Q.How do you know that... A. turned the steering wheel and the rear wheels didn`t move
get you camry or vn holden checked by racq ..otherwise get people that know what there doing ..not clowns sponsered by ford ,holden etc
mate of mine had his car checked out by racq and they did an awesome job
found heaps of problems for teh dealer to fix
i got mine checked out by chapman and chapman, they were good too
yeah we did a full check over - bushes and everything seem to be good, no unusual signs of wear - heater hoses and fire wall fibre was all in tact and looked brand new. No signs of welding or anything on the seams welds around the car either. THe thing i don't know is RB series engines, 12DFY, how can I get in contact with you? would really appreciate someone elses knowledge before I take the plunge.
cheers
Yeah I plan on getting a tune done by chapman and chapman, my good mate and mechanic used to work there, but getting a chance with him to go from brisbane to the goldcoast is hard lol
Yes I can agree with jake32. I have now had two cars inspected by State Roads (Vic & Qld) and I can definitly recommend these guys. Very comprehensive test, I actually relied on this test to purchase my R34 as I could not view the car myself. Thanks jake32!! :P
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
