Hey guys....
I just got the boost controller kit for the apexi and went to install it but came to the solenoid cable and got a little stuck.....
Plugs in fine on the solenoid end but when it comes to the other end dont have much of an idea.. it doesnt fit the original plug and not sure what to do.
Do I have the wrong wire?
here is a pic of the wire.
Oh car is R33 GTST
https://www.sau.com.au/forums/topic/130947-apexi-boost-control-kit/
the boost control kit plug, is it the 3 pin or 5 pin kit?
what car do you have?
if its the 5 pin kit
then the solenoid power and ground run to the loom
and the 3 wires for map sensor run off the boost kit loom
if its the 3 pin kit
then the solenoid power and ground run off the STOCK car loom
and the 3 wires for the map sensor run off the boost kit loom
look at your ecu's wiring diagram to find what wire is wastegate control, usually wire #25. run this to the solenoid and run the other to power from somewhere (im pretty sure).
the powerfc faq shows u how to connect up both
it a 3 wire one....
right so the 3 wires for the map sensor
so you use the factory boost control wires to run the solenoid
just chop off the plug and match the wires
so im guessing that the black wire is positive and white is positive on the car?
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
