What I really want is just a consult cable that has Video out RCA on the other end, with rom software to display all the important readings similar to the 8 line display of a factory R34GTR console. Then I could just plug it into the aux-in of my double din DVD player and I would be done. I wish someone would make a device like this - quite easy to do! Are you able to do something like this NewKleer?
  • Replies 279
Posted Images
its very difficult to do (20x more effort than what ive done in the character screen), but there are existing products around that do similar to what you're after. hks camp (discontinued, i think this is similar to r34gtr console) and techtom vlogger. but theyll cost like $400+ if u can get them
Its is possible to modify an R34GTR MFD to output to a standard screen, but for most ppl it is to much time, effort & $$$.
Personally I'd be happy with software for PC that could be skinned to act/look the same as the 34 MFD, possibly using ECUtalk or similar as a service if need be... unfortunately nothing half decent is out there(that i've found) so ill end up having to sort it out for myself lol
btw. HKS Camp 2 has been released, but still very $$$...
Its is possible to modify an R34GTR MFD to output to a standard screen, but for most ppl it is to much time, effort & $$.
btw. HKS Camp 2 has been released, but still very $$...
With the appropriate data steams I could probably manage to do an interface in Flash/AIR.
at some point i hope to be able to define some interface that people can code their own 'gauges' for use in ecutalk software, eg a bar guage or whatever
would people prefer a plastic enclosure similar to the last lot, or a metal one?
would be similar size etc, though the metal one would have holes on front to screw lcd onto (plastic would be all snap together, no screws), would weigh a bit more
metal one may end up ~$15 cheaper
ill try get pictures of the metal prototype soon
yeh metal would be painted black (perhaps a few white)
theres a chance id go both - get 100 metal, and then say 50 or less plastic - but that would mean theres more than $15 difference as the plastic will cost more for lesser quantity. (maybe say $185 vs $210)
whichever one is ready to be made first will probably be the one im more likely to go with, as its been forever and then some waiting for the enclosures design/manufacture
V1 users, you can send back your displays for upgrade to final v1.0 firmware, which adds the trip meter screen. more info on the website
V1 displays can be traded in for $100 off a V2 display.
And here's a rather dodgy phone picture of a prototype metal enclosure. Note that the LCD isnt secured to the metal box in this image, and its sitting a bit high, and the holes for buttons/USB are slightly larger than needed.
din is roughly 180x50, so it will be less than single DIN size. im not making it full single DIN size because not everyone would mount it in DIN, and it would cost more for "empty" space.
Metal or plastic I'm easy... but I'd probably end up putting a single-DIN plastic spacer over the front to space it out to a DIN size as it'd probably look better than having 'ears'.
once ive got all demand covered i might get some form of DIN mount made up that it can slot into, though this would be the 'ears' you talk about (unless u meant ears would be empty space).
leaving that to last because users themselves may come up with good ideas for mounting (even modifying din pockets for the display to slot into)
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
