no worries
osman ive put you down for blue. still need to update thread to v2 stuff, maybe next weekend
currently we're about a 50/50 split for blue/green lcd so this might mean blue will only be +$5 over the green rather than $10 (due to higher quantity)
  • Replies 279
Posted Images
updated. reminder here is current list of people (both via sau, pga, and the website directly):
http://www.ecutalk.com/consultlcd/lcdorders.php
and this avi shows the blue screen:
http://www.ecutalk.com/consultlcd/consultlcd.avi
the screen was slightly covered to keep competing light out, keep that in mind that you wont be able to place it anywhere in direct sunlight (or other bright competing light). can always send it back to be swapped over to a green one for cost of postage if you dont like the blue.
unfortunately not, only those 2 alternatives at the moment. its extremely difficult to find any 20x4 screens that fit within din size (most are 60mm high which is > 50mm din size)
if u want to order 1000 however, it can be done :laugh:
ive put you down for a blue one
here's design for enclosure. unlike the last one there is no pcb slots, so not much of an issue assembling it.
adjoing hole for cable from right to back, so you can reposition cable depending on where you are mounting it without taking it apart
received prototype today. here's pic of it (its on an angle which is why it looks like enclosure window for lcd isnt big enough, but its fine)
ordered 100, maybe have them start august. finally!
added you. and here's some more pics of it. front, side (microsd slot for future hopefully), and rear showing the right/rear cable exit (can switch between either depending on how you want to mount)
do the buttons look weird? would black/dark grey look better?
yah after fitting one with black buttons, looks less of an eye sore :D
no idea why i didnt think of it sooner, im sure people can figure out the 'left' and 'right' button without them being different colours!
ive ordered some black ones so should be good.
have created a new thread for v2 displays:
http://www.skylinesaustralia.com/forums/Ec...Di-t228314.html
dont post in this one anymore (send me a pm if you have issue relating to v1 display)
Guest
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
