  • Replies 83
Posted Images
go both!!! 2 gold for the passenger side and 2 grey for the drivers side.
Practise doing that stuntman "driving on two wheels trick" and then you can choose racey/bling depending on your mood.
now you can please everybody and yourself! :happy:
id say go the gunmetal (out of those 2)
id go with tofu though, and put white on it if it were my choice :P
the thing that puts me off gold wheels, is every second rex has it.. ruins it for me unfortunately.
yea they look good can i ask whats the differnce between 225 and 235 tyres ? the guy told me i got a choice between them 2 and the choice between falken and hankook what you guys think and i think im heading towards 18's in gold now gona order nextweek
sam
definetly the gold and in 18s , better looking fit to the 33 gtst I think . to big wheels with tiny tyres can look silly IMHO
put gold racing stripes and gold sponser type lettering down the side
and paint you calipers blue to match the blue lock nuts you buy for them
:ninja:
the bigger the wheel, the sh*tter the ride. i have 20" wheels on my R33, and while there is no rubbing etc and the wheels sit under the guards, ie slammmed hard, the ride is hardly comfortable...
i put my stock 16s back on and it rides so good now! 18s with dish are the ideal wheel for a R33 i reckon.
As for tyre size, the 235 tyre may be too wide with a 19" rim. I know that if i fit 235 tyres to my 20s, i need to shave a suspension arm slightly to make them fit. the 225s i have on there at the moment are fine though.
here is some pics of mine with big wheels, looks hot but comfort is certainly lost....
http://www.skylinesaustralia.com/forums/in...howtopic=129884
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
