Sounds more like that it is spinning when it shouldn't. This is because it's a viscous clutch fan, and when it fails, it locks up.
If you start the car when it is dead cold, it should spin up and then come off after a minute.
Or, to test whether it has seized or not, tomorrow morning, open the hood, and try to spin the fan with your hand (car off!). If it resists a LOT, then it's seized and you need to buy a new one. Changing it is pretty easy though (4 bolts), and if you wiggle it, just a little bit, (hehe) it should slide past the radiator shroud.
can it still eb driven until my new fan arrives? and where to get a new one? how much?
Edited by Suspense
You can drive it as much as you like. It will make a lot of noise from the air being pushed, and it will still cool everything (even when it DOESN'T need it).
New fan I think is under $200... Call Nissan?
the clutch on it has FAILED dude. this means what it does next is anybody's guess. which means it may loosen at any moment and start free spinning, i.e. not cool your motor.
if you're going to spend $200 on a clutch fan, why not upgrade to an electric thermofan for a bit more. i'll be doing that mod soon.
Don't panic....... Pull the fan & clutch off, if you're in Sydney, go see the boys at Just Jap in Kirrawee or SSS in Giraween ( or the like ) and grab a good condition second hand clutch off them !! Just make sure it bolts up to YOUR fan and looks the same ( but better than yours ) and away you go !!!
I was a bit suss on my clutch ( fan ) and scored an almost new clutch off an R34 RB25NEO that fit perfectly in my R32 RB20DET fan and works great !!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
