Um by the way...we still havn't established what the car actually already has???he may have half the stuff that paul 33 has listed so in that case...where could his extra money be better spent? a better turbo perhaps or maybe a bit more tlc to drivetrian or suspension in order to put this "250 - 300kw's" to the ground
He said the car is completely stock, so it will have none of it.
  • Replies 91
Did you read the first post?
I think it was clearly established what he does, and does not have
The car is completly stock and i'm wanting to use it on the road as well as one the track.
utilizing an air flow meter is going to offer a safer tune every time, and at those power levels the right type of afm isn't really going to lose you massive amounts of power, so personally i know what i would be using. check your facts and your "reliable source".
If GTR injectors aren't the straight drop in then what is?
so s15 injectors are? any others that are higher than 480cc?
You are better off going for some Nismo ones. Will cost about $900 all up and fit straight in. Cams will also be required for a safe 250rwkw and I would be budgeting $15k for the whole lot including labour
ahh guys, where is the love? i think some people are getting a bit hot under the collar.. let's examine the facts:
FACT 1: An afm is a better option for the kind of setup this guy is after
FACT 2: After a careful read of FSTR32, both he and his "reliable source" don't have a clue what they're talking about and FSTR32 refuses to admit this even though he/she has been presented with credible evidence to which he/she has replied to as being "WEAK"
so, the solution? FSTR32 either shuts up or pulls his/her head in and we can all go back to being happy forum users.
I would love to get nismo ones, but I can get them s15 injectors very cheap.
Well actually basically anything coming off a japanese car.
Just wanted to know my alternatives
nismo 550 or 740 injectors are straight swap, or you can go the sards which require an injector collar to fit.
I have the sard 850cc on mine, which is overkill until the engine is rebuilt and I can get the most out of the gt3540r
Just because an engine produces 369rwkw with an AFM doesnt mean the AFM isnt causing a restriction and that there is nothing wrong with the AFM as you say. Your logic is to look at the end result without a proper control (ie no AFM) which is nothing but inviable.
Honda and certain toyotas run MAP. Have you driven a vtec-powered car?
Youre always the first to say if its not needed than dont buy it. Well what about this case? The afm isnt needed and unless youre a track racer where a split second counts the AFM isnt needed at all. He can save himself money on not buying an AFM.
Better yet, you can even see the video and look at the nice telly screen of it. :)
How good is that eh? Stuff having a sheet, live video recording is a joy.
http://skylinesaustralia.vidiac.com/recent...a697e4dad6e.htm
That also includes a backup run of 358rwkw with a bit less timing.
Safe to say there is nothing wrong with an AFM based car at all.
WHAT THE HELL IS A AFM??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
My tuner has expirience with both MAF and MAP applications for the RB's.
If he tells me in his expertise that the AFM is not a restriction, then i'll believe him based on his testing and applications.
I trusted his judgement and made more power than anyone else said was possible at the time.
When a PowerFC is $900, and the AFM $250-$300 thats $1200.
Would i be right in saying a MAP based ECU is a little more expensive in most cases?
The closest that comes to mind is $1400 at the very least. I think more decent are wire-in at a $2000+ cost
So cost for cost, the AFM + PowerFC Combo will works out cheaper.
As stated he is in Vic, and *most* tuners will prefer to use a PowerFC down here as opposed to anything else.
Well not actually because a decent ECU that utilises the MAP sensor will set you back around a minimum of $2000 installed. Then the tune on top. So he would, in fact, be outlaying more money for it. There is nothing wrong with an AFM, there is also nothing wrong with a MAP sensor. Both have their pros and both have their cons. You can make more HP from a MAP setup but his aim is only for 250-300rwkw so the Afm would do just fine.
airflow meter.
the cost of saving on an afm and gaining possibly 0 rwkw or even 2rwkw and dealing with the crapness of map sensor driven tune is not worth the $300 saved
Air Flow Meter (AFM)
If you look near your airbox, there is a sensor in the pipe going to the turbo with a wire/plug on it.
That is the AFM :)
AFM stands for Air Flow Meter. Which is technically incorrect in this case as the Nissan unit uses a hot wire setup which should be referred to as Mass Air Flow Meter or MAF meter.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
