PRICE DROP AGAIN
this is a relist with a new price,
need to sell, open to offers
Item: R33 Nissan Skyline
Reason for Selling: want a 4 door 4 wheel drive. possibly swop for bug eye wrx
Price and Payment Conditions: $19500 ONO
Extra Info: Late 1993 Nissan Skyline R33 GTST (series 1)
This is a reliable high spec car going for a very reasonable price. No expense spared in the modification process and always used top tuner and mechanic (Chapman & Chapman Automotive)
Excellent performance but still a daily driver
Power: 350HP ATW
Miliage: 85 000 kms
Engine Modifications:
GCG Hi flow Turbo
Tomei 550cc Injectors
Blitz Front Mount Intercooler (plumbs back to standard holes on passenger side)
Os Giken Exhaust Cam Pulley
Turbosmart type 2 BOV
3” turbo to CAT
3.5” CAT back exhaust
3” Hi flow CAT
HKS mushroom filter (with spare insert)
Z32 AFM
Bosche 979 fuel pump
Bosche fuel damper
Sard Fuel pressure regulator
Carbon Fibre cold air intake box, with standard snorkel fitment
19 row oil cooler
Oil filter relocation kit
Electronics:
Apexi Power FC, with hand controller
Apexi AVCR boost controller
Auto meter Shift light + Tacho
Suspension and Brakes:
Tanabe coilovers
Front adjustable castor rods
Rear Whiteline camber kit
Whiteline differential cradle bushes (pineapples)
DBA 4000 Rotors with Ferrodo race spec pads
Front and rear strut braces
Exterior:
Carbon Fibre GT wing (conforms to QLD road rules and is legal)
Flush boot “drift” wing
M spec front bar, with intercooler space cut out
400r Side skirts
Black Bonnet
Other:
Radiator air guide
Skyline floor mats
Immaculate interior
17” wheels 9” wide rears
255 Nankang’s on rear
235 Toyo’s on front
Mines 300kmph Speedo
This skyline has well over $12,000.00 worth of modification done to it and all has been carried out by Chapman and Chapman automotive.
Serviced every 5000kms and always used Motul 8100 oil.
Timing belt was changed when I got the cam pulley installed (3000kms ago)
Gearbox oil was changed to redline shockproof as soon as I purchased the car (march 2004)
Contact Details: neil smith 0431912336 [email protected]
will swop for bug eye WRX
finance can be arranged
https://www.sau.com.au/forums/topic/131071-350hp-r33-skyline/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
