Just wondering if anyone has had experience with getting their engine 'carbon cleaned' - ie: take it to a mechanic and they run some sota cleaner through the motor whist its running. Its not the same as squirting a can of carby cleaner thru the motor.. or is it??
Can anyone confrim this is worth doing?? I've heard large carbon buildups on the pistons can cause engines to ping etc...
https://www.sau.com.au/forums/topic/131100-carbon-cleaning/
I can't imagine it being required for a modern engine and didn't even know people still did it !
Way back in the old days we used to use brake fluid to de-carbon ;) Worked really well but I wouldn't suggest doing it nowdays :D
https://www.sau.com.au/forums/topic/131100-carbon-cleaning/#findComment-2424531
We used to do that one too. I knew a guy who worked for a dealership many years ago that tried the water de-carbon trick on a customer's supra and got it wrong ( bent 2 rods, lol ).
The brake fluid trick was for severe cases and just to clarify, we didn't run brake fluid through the engine while it was running :D We used to soak the pistons / cylinders for about 2 full days which lifted the carbon build-up. Won't go into the whole procedure because it's illegal and has damage potential if done incorrectly.
https://www.sau.com.au/forums/topic/131100-carbon-cleaning/#findComment-2424609
They use ATF fluid in rotors to de-carbon the apex seals if it has been sitting for a while. Not done whilst running though.
Mafia was starting a gb with water/methanol injection kits not long ago, reduces pinging and also cleans the internals of the engine. Could consider something like that... would also prevent the problem in the future.....
https://www.sau.com.au/forums/topic/131100-carbon-cleaning/#findComment-2426158
I used to work for the Shell mechanical garages, and we had proper carbon cleaning machines that use high pressure and a special wynns product called "CARBON BLASTER". The results of b4 and after were massive, wish i had pictures of all the carbon buildup that actually comes out when the machine sucks all the old crap out.
Not entirely sure how the machine actually works, but the results from actually getting ur engine properly cleaned with a specialist machine vs just a can of carby cleaner, throttle body cleaner etc is 2 different leagues. Im not sure on whether u should get it done but we have done it from hsv's to bmw's but only if we thought the car would really benefit from it.
From memory it cost $120 - 150 depending on quantity of product used and takes 30mins - 1hr to do. Ask around and see if your mechanic actually has a proper carbon cleaning machine. not a can of carby cleaner!
Cheers Pete (BOOSTA)
https://www.sau.com.au/forums/topic/131100-carbon-cleaning/#findComment-2441078
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
