Just checked out the new HSV range at their website. I like it execpt for the rear tail lights to small or something, just dont look right to me.
Only an extra 10kw was added taking peak power to 307kw, the GTS doesnt have any more power than the clubsport which is disapointing I thought it should have at least an extra 50kw or so. its suspention sounds impressive magnetic ride control (MRC) it offers different modes of handling/comfort. Anyway what do you all recon?
cheers
HSV Website
https://www.sau.com.au/forums/topic/131133-new-hsv-range/
  • Replies 103
Im a bit skeptical on the 0-100 time, mainly cos its a heavy mofo of a car......
But I quite like the new shape - I have seen the same red ss around the mount waverley, monash uni area - looks pretty nice. The only downfall is, the car is soo big, that I wont be able to see over the steering wheel....
https://www.sau.com.au/forums/topic/131133-new-hsv-range/#findComment-2425810
0-100 4.96 seconds? thats pretty f**kin fast for a holden
I'll believe the 0-100 time when I see it independently verified by Wheels/Motor magazines. They reckoned the old 300kW CB4 powered GTS commies could do 4-point-something, but they never did...and the new barge will be even heavier. Looks like Commonwhores are being riced-up at the factory these days....sorry, just remembered the '96 VS GTS-R 'Bannana Boat'.
https://www.sau.com.au/forums/topic/131133-new-hsv-range/#findComment-2425987
They did get 5.1 seconds out of the VTII GTS from memory pretty darn quick. The base model is said to weigh 100kg's more than the previus model. So I recon the HSV version would not be much under 2 tonne bloody heavy for a sports car.
https://www.sau.com.au/forums/topic/131133-new-hsv-range/#findComment-2426094
The car is fine apart from the rear lights... A HUGE let down for the whole car.
Bad move by holden, more weight, worse fuel economy. But hell hopefully the LS2 + a little more top end power helps push it along quicker than the previous model..
Nothing wrong with going quicker and quicker from factory. :)
https://www.sau.com.au/forums/topic/131133-new-hsv-range/#findComment-2426357
Looking at it more closely it looks pretty good I think, lines flow pretty good. Other than that back bit above the light, thats a bit messed up with pannel joints. Seats look nice and comfy for the average person whos going to buy these. If its true about the braking then they pull up bloody fast.
Stereo I dunno about, I think 11 speakers is over kill if they were to do a true premium sound like the Audi A8 or something, but hey most people again wont know what its meant to be like, so they will think its cool.
Really end of the day doesnt matter cause they cant make anymore atm can they!
https://www.sau.com.au/forums/topic/131133-new-hsv-range/#findComment-2427243
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
