- Original GTR32 Strut tower brace
(Black ends with silver centre bar excellent cond.)
Make an offer!
- Original GTR32 floor mats (in good condition)
Make an offer!
-Apexi twin pod filters (done 2,000ks if that! as new)
$325 ono
-VOLK RACING 18" rims (AS NEW, silver with polished writing
$2,500 no tyres
- 3" mild steel cat back exhaust (super cat stainless muffler)
$450 ono
- HKS type 1 TURBO TIMER (has 0-100 timer etc includes harness)
$300 ono
- 3" cat pipe
$50.00 or case of beer :uh-huh:
PM me...
I might be interested in a few parts.
Will the strut tower fit if I have aftermarket (Tein) suspension?
Do the pods have the adaptors to fit an R32 GTR?
And does the turbo timer have the wiring harness/adaptor for R32 GTR? And also does this turbo timer remove the speed limiter??
thanks,
Andrew
YES
YES, FULL KIT + INS
YES
NO and I don't know of ANY that do!?
All the bits just came off my 32GTR before I traded it!
YES
YES, FULL KIT + INS
YES
Thanks for that mate.
Im more interested in the turbo timer than the other parts.
I think there is 1 turbo timer that does remove the speed limiter, a blitz one i think from memory???
Anyway Ill get back to you real soon about the turbo timer (if its still for sale)
thanks,
Andrew
I saw the picture after I posted. Just stupid and lazy on my part.
I'll give you $100 plus shipping, direct deposited into your account before you ship.
you can call me or email me if you like
mark@test-rite.com.au
0411 471 684
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
