hey guys, i got a little bored today so i went to the local auto parts store picked up some 2'' gauges (volts and boost) and a shift light, and decided to replace the triple gauge cluster. took the cluster apart and removed the old gauges, the new 2'' gauges fitted in the factory holes easy with no cutting required, i just had to make a face plate up for the shift light. pretty easy low cost mod for those people interested.
thanks
Justin
this is exactly what I want to do, only with Defi link Gauges.
can you take a photo of the back of the unit with the gauges in them now?
will take a pic tommorow for you.
thanks
Justin
didnt you have a oil temp gauge? isnt oil temp more important than battery voltage??
i love seeing people do stuff when bored! good work!
steve
true oil temp is more important, but harder to wire up. i may end up moving the shift light some where else(surgestions anyone?) and put another gauge(oil temp) where the shift light is at the moment.
main reson for changing the cluster was to have a boost gauge capable of reading more than 1bar and to also have a PSI gauge.
i would have loved to put some better gauges in ie. defi but i just dont see the value for money.
thanks
Justin
Nice job, hope you have an easy way of turning the shift light off if you use this on the road too because it's gonna piss you right off after a week of driving at night!
that was my next question, coz now u cant put a cap on it becoz its behind the plastic lens, and those things are really bright i.e. blinding
Are you sure they a 2" gauges? I have several pics of people who did a similar thing and for alot of them, the gauge sticks out, looked like they had to do away with the plastic lens.
yeah the gauges are definetly 2 inch diameter, i think the bezel around the speco gauges are pretty small compared to some other gauges. i only just had room to fit the plastic lens back on, prob only a mm to spare.
i only drive the car on the weekends, and hardly ever rev it to 7000rpm(which is what the shift light is set at). the only real time i rev it to that is a the dragstrip.
hi guys
sorry it took a while to get a pic of the back of the unit, ive been heaps busy. anyway here are the pics of the back of the unit.....
i have a cheap ($180) shift light. its not LED and it doesn't bother me at night. it is all about how high you set them. if you set them at 6500rpm, then you are only going to have it come on when you are fanging it. if you are just driving normal it won't come on.
can you actaully look at the guages legitamtely and concentrate on driving at the same time? i find even looking at the factory clustor takes away my focus on the road ahead for a brief second
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
