i got a set of tein height adjustables on my r33 and was havin trouble cracking the 2 locknuts apart as i wana lower it. i managed to get the bottom one off as i drowned the thread with INOX spray, so that was freed up, i managed to get that loose with a stilson and pipe.
the second 1 (one that the coil sits on) wouldnt move. i sprayed it heaps, even spring clamped the coil to take pressure off it, and still couldnt free it.
NOTE: i didnt take the ket so i used a long screwdriver and hammer.
can any1 give me advice to tricks to loosen it?? i cant get the stilson on it coz there aint enuf room to grip on the ring..
thanks
https://www.sau.com.au/forums/topic/131164-tein-height-adjustables/
do not take anything hotter than a hair dryer to your shocks, an i cant see that really doing much good. as seen on most shock absorbers is a warning "DO NOT HEAT"....
some how get more leverage on your C spanners, slide a pipe or something over it? hammer an screwdriver may help jar it, but be careful not to damage the ring. only other suggestion is use something like RP7/CRC/WD40 etc.. leave it for 5mins an come back an give it another go.
if all else fails you will have to take the strut out disasemble it and split the nut off the thread, check the dia of the thread before you do !!! it shoold be a generic metric thread size and you should be able to buy a new one from any half decent bearing store
when you go to give the nut a tap with a hammer try and use some thing like a copper hammer it should not damage the nut but still give a decent hit . if you do end up needing a nut you need to know thread dia and thread pitch ,eg ,1,1.25,1.5, 1.75 you will need to get hold of a thread pitch gauge to measure the thread, when you do get it all free and moving use a good anti seize to stop it from happening again , any way best of luck.
where can u get a C spanner from?? i didnt egt it with mine as i bought the car second hand and wasnt given it
also try the plumbing section of the hardware store, seriously there like a third of the price.
putting the shock in a bench-vise helps also.. just remember not to clamp on the casing, damaging this will f**k your shock up, clamp at the bottom like where the bolt goes through and attaches it to the lower control arm... but once you got it in the vise you can go to town on it... with your c-spanners and such...
Just a passing thought. The newer Tein C Spanners have the option to put a big socket breaker bar on them to get more levereage. They are expensive though. Maybe $80 a pair. See if any one local has some yhou can borrow.
Regards
Brad
Regards
Brad
or once again go to the hardware store and buy a pipe of some-kind to fit over the end of the spanner handle (which ever you decide to get) and wah-lah more leverage.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
