Hi all,
need some help or ideas.
i have a 95 r33 gtr that the 4wd system isnt working.
as soon as u start the car the 4wd light illuminates.
i have swapped attessa computer, g sensor all 4 abs sensors and we still only have 2wd.
i can hear the pumps at the rear pumping at start up, but we have a problem somewhere.
any ideas would be apreciated.
Thanks
https://www.sau.com.au/forums/topic/131185-need-help-gtr-4wd-problem/
might seem stupid, but you've checked for hydraulic leaks, the fuse, and bled the attessa system?
P.S: that pumping noise is probly fuel pump anyway, dunno how loud attessa pump is compared to fuel pump, especially at atsrt up
Edited by VB-
hi yep checked the obvious stuff, from my understanding the only things that can cause a issue are hydraulic pressure or an elec fault.
attessa is bled, 33 doesnt have a fuse like r32, no leaks.
the pumps prime as soon as u turn the ignition and they are very audilble on the gtr.
thanks anyway
... 33 doesnt have a fuse like r32, ...
Pretty certain they do, down by your right knee, just like a 32.
Fluid in the reservoir is at the right level (checked with IGN = ON)?
TPS connection is working?
